New LS1 Owners - Newbie Tech - 35th Anniversary question
View Full Version : 35th Anniversary question
vegitaz28
02-10-2007, 09:21 AM
I was wondering is there a way that I can find out what the actual number off of the production line my car is since it is a 35th Anniversary Z28? I was wondering was there a different number from what the vin decoder says?
Bad Boy Racing EPTX
02-10-2007, 09:44 AM
Why dont you go to a dealer and run your VIN# they should give you a bunch of info and the codes on the door will probibly show you things you did not know about your car.
BlazinT/A
02-10-2007, 10:07 AM
i believe its the last 6 numbers in your vin
JL8Jeff
02-10-2007, 11:17 AM
There's nothing special about a 2002 Z28, they are all 35th anniv cars. But the 35th anniv SS was a special package and I think SLP or GM should be able to identify what car it was by the VIN.
Time2Kill
02-10-2007, 11:39 AM
Only the SS Camaros were given numbers by SLP. The 35th LE SS has a SS number and also a 35th LE number. Z28 only goes by the numbers on your VIN
ur jlus
02-10-2007, 11:57 AM
The last six #'s is where you start and then check the door sticker for the month that will be as far as you'll get. I call mines "The Preemie" because it was made in May '02 which was an early start up by GM for the final year. Mines came in the first 2 weeks of '02 production. My vin is in the first 630 or so made for '02. I wasn't able to narrow mines down any further. Hope this helps. BTW the vin #'s for '02 range from 2G1FP32G222100001 THRU 2G1FP32G122172467 ACCORDING TO THE CAMARO WHITE BOOK.
JL8Jeff
02-10-2007, 12:46 PM
You mean May of 01? May of 02 would be near the end of the run.
vegitaz28
02-10-2007, 04:11 PM
thanks for the info.
Gold Z
02-12-2007, 11:43 PM
Even the V6 Camaros made in 2002 are anniversary models.
Weezzer
02-13-2007, 11:22 AM
There were no officially designated 35th anniversary Z-28's made (or V-6's); however, there were approx. 3110 designated 35th Anniversary SS's manufactured by GM and SLP. Everyone of them were red and came with the checkered flag decals on the hood.
Gold Z
02-13-2007, 09:57 PM
Every 2002 Camaro made had a small plastic plate which said 35th anniversary Chevrolet Camaro on it. It was located above the A/C and radio stack and to the right of the A/c vents.
shiv15
02-14-2007, 11:51 AM
I think you mean 01 because my 02SS was made in Oct 2001..
02silvaZ
02-15-2007, 02:14 PM
according to what i was told by a friend at a dealership, the only cars that got 35th designation other than the SS were convertible and t-top cars V6 & V8, hardtops did not get the designation, i could be wrong but this is what i know right now
