True 3" Dual Side Exit Twin Turbo!
Old 02-10-2007, 12:04 PM
93formto98T/A's Avatar
Default True 3" Dual Side Exit Twin Turbo!
Hey guys, I had been planning this exhaust setup for awhile and had it done up this past summer. Finally getting around to sharing with you guys. As mentioned. It's 3" pipes coming right off the twin 3" turbo downpipes going under the car and into the cab then 90 degree out the sides. I fabbed aluminum heat panels which are not done yet. I'm going to take them off and have them chromed. I'm running 3.5" race baffles for mufflers as the turbos quiet the exhaust already. It has a healthy exhaust note at idle and 3500rpm+ the thing sounds like a big block open header dragster. And not to mention it reduced the backpressure from my previous SLP loudmouth down to zero. I'm thinking about trimming the tips in a little. Let me know what ya think. Unique isn't it??
Attached Thumbnails True 3" Dual Side Exit Twin Turbo!-cnv0159.jpg   True 3" Dual Side Exit Twin Turbo!-cnv0168.jpg   True 3" Dual Side Exit Twin Turbo!-cnv0171.jpg   True 3" Dual Side Exit Twin Turbo!-cnv0173.jpg   True 3" Dual Side Exit Twin Turbo!-cnv0180.jpg
Old 02-10-2007, 12:15 PM
themadspoon's Avatar
Personally not a big fan
Old 02-10-2007, 12:21 PM
ProjectCamaro's Avatar
Wow, that's awesome!
Get some clips of it, I'd love to hear it.
Old 02-10-2007, 12:24 PM
DSG
DSG's Avatar
Looks like the Offset to your front tires is off a bit.
Old 02-10-2007, 12:26 PM
Offset it the same. I am not running the corner ties under the bumper so it sits out a bit wider.
Old 02-10-2007, 12:32 PM
Breathtaker's Avatar
The pics I was waiting for, yep, that's pretty cool and unique, chrome will look much better and match with your wheels, but not a big fan of the headlights tho. You invested quite a lot of money in that car man, keep up the good work!
Old 02-10-2007, 12:36 PM
LS1Tech Sponsor
Superman09's Avatar
wow man, your car is really 1 of a kind! I really like how you've made it stand out from others.. if anyone bashes you, tell them to line em up, lol as you have the power to back it up as well Great work with the car as a whole, really cool to see someone doing something unique to their car and stepping out of the norm, big props!
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old 02-10-2007, 12:38 PM
LSONE's Avatar
Wow, and under body shots?
Old 02-10-2007, 12:41 PM
Thanks superman, hope to see action clips of your new setup soon.
Sorry, I don't have undercar shots.
Old 02-10-2007, 01:35 PM
flash12t's Avatar
car look pretty sick . . but ya really cut it down a lil bit more. the head lights take a while but they start to grow on u .. lol
Old 02-10-2007, 02:44 PM
02SOMLS1WS6's Avatar
Wow thats original! I couldn't bring myself to cut a hole in the side of my car though. Its cool that you had the nads to though.
Old 02-10-2007, 03:24 PM
NassyVette's Avatar
Neat idea, I think cutting them closer to the body would help the looks.
Old 02-10-2007, 03:45 PM
carado1984's Avatar
and maybe a little lower and diff tips maybe coming out of the side skirt
Old 02-10-2007, 03:50 PM
RooRnZ28's Avatar
yes, i agree.... good job though!!!
Old 02-10-2007, 04:33 PM
Mike00ss's Avatar
Wow that’s definitely one of the most Unique setups iv seen, any pictures of what it looks like under the car?
Old 02-10-2007, 04:43 PM
All aspects of this setup were researched before I did it. There is no way to have the tips come out at the side skirts because the body has no sharp angle, it rounds off and that's where the rear frame starts so it's all structural there. If you take your sideskirt off you will see that the body is just as low as the skirt is-the skirt just gives a lower appearance because it provides a shaper contrast to the ground. There's no clearance to have an exhaust hanging down another 3", also my car is lowered 3". Had to go into the car and back out. I'm thinking about having it redone and using dual 4" pipes and then having the tip just 1.5-2" out instead of 4" out.
Sorry, no undercar shots.
Old 02-10-2007, 04:46 PM
haha, I hear ya man. You can't have any doubts about it if you're going to do it. You gotta commit to making it turn out the way you want it. Sometimes it comes out right, sometimes it takes alot of work but there's no backing out once there's a 3" hole in your car.
Old 02-10-2007, 05:19 PM
SIK02SS's Avatar
great idea
if anything, trim it flush, and then paint the piece surrounding it to match the body. it would then be even more so
Old 02-10-2007, 05:25 PM
slick1851's Avatar
Please cut the tips down, there sticking out way way to much...All race cars have them sitting almost FLUSH with the metal heat sheilds.
Yours is way to far out, other wise I love the idea, just a bit sorter!
There a fine line between function over forum, and tacky...but I like what your doing just sorter
Old 02-10-2007, 05:26 PM
slick1851's Avatar
2.0 inch out is still to far.....1-1.5 at the most
Quick Reply: True 3" Dual Side Exit Twin Turbo!
