Vss
Old 02-11-2007, 01:23 PM
Blown93Z28's Avatar
Default Vss
I just finisihed the 6-speed swap in my 93. I havent it all together exhaust the wiring. im not worried about reverse lights and clutch starting, but how do i go about fixing the VSS problem? I dont have any of the M6 harness. Does it just plug into the t56? Thanks
Sean
Old 02-11-2007, 09:44 PM
SSPerformance's Avatar
you need the pig tail from a t56 harness and u will change it.... ur spedo will be off by about 50%
Old 02-14-2007, 08:56 PM
Blown93Z28's Avatar
why will it be off by 50%? Wont that make the computer think its going faster or slower than it really is then making it not run correct?
Sean
Old 02-15-2007, 07:39 AM
camaroguy26's Avatar
I think the VSS is the only sensor that's the same for the A4 and T56? If I remember right all I had to do was lengthen the wiring. But yes your speedo will be off because the gearing is different in the T56 from the A4. 50% seems a little high though? I think it's just 5-10mph difference. You'll be going faster than what your speedometer is reading.
