Drag Racing Tech - Those with pin on hoods, please come in
tektrans
02-11-2007, 02:09 PM
Just got my WS6 VFN pin on and my question is since the airbox doesn't seal to the hood anymore, will all that extra airflow running under it affect the car at high speeds? Can the hood fly off?? I know Noyzee lost a hood once.
Rogue86
02-11-2007, 02:15 PM
If you use several Dzus fasteners rather than just 4 pins I think you would be fine.
Noyzee
02-12-2007, 08:11 AM
i had alot of dzus clips. i had 4 on each side, 3 up front, 2 out back, it ripped the rivits right out!!!
i got bigger rivits and washers. drilled the hole, stuck the rivit in, then the washer, and crushed the rivit, this made a nice large area to hold, and since has gone 9.0 without an issue.
tektrans
02-12-2007, 10:59 PM
Well I won't be going 9.0 anytime soon. :)
I saw these DUZ washers that go on the underside of the hood to make it a stronger install- I ordered them so hopefully I can make it work.
Thanks.
mrdragster1970
02-13-2007, 11:08 AM
Don't skimp, at 155 I had my hood start to take off, added more dzuz and it never moved again. 4 in front and back minimum. I also love those small aluminum lips you see guys use, strongest way to mount hood.
Noyzee
02-13-2007, 11:56 AM
you can see in this pic, i cut strips and rold the ends so it looked good. i rivited this to the stock lip, then all the rivits ripped out. put the washers in, and no more problems.
5 on the sides, 3 up front 2 out back. and i blocked up the holes on the nostrals no more issues.
tektrans
02-13-2007, 03:49 PM
I put in the side brackets today, 4 on each. The way the trans am hood is I'm looking at 6 up front and now you say 4 out back. That's eighteen!!!!!!
I'm gonna have to buy more rivets................:)
9sec93
02-13-2007, 05:59 PM
i dont see a pic :confused:
9sec93
02-13-2007, 06:06 PM
for those with pin-on hoods, could you please post pics. i have to pin-on my extended sunoco hood and i havea few ideas on how i want to do it but would like to see what others did. thanx
JRcamaroZ28
02-14-2007, 05:53 AM
what type of rivits are you guys useing?
Noyzee
02-14-2007, 08:48 AM
haha, my bad.
http://img.photobucket.com/albums/v357/Noyzee/Under%20Hood/P5240047.jpg
http://img.photobucket.com/albums/v357/Noyzee/Under%20Hood/P5240046.jpg
these are my rear brackets. they look good once the cowl piece goes back on
http://img.photobucket.com/albums/v357/Noyzee/Under%20Hood/P5240051.jpg
mrdragster1970
02-14-2007, 10:06 AM
Buy more rivets, you will be glad you did, and you will be done once and for all.
I have 6 dzuz in the front, 4 in the back and only 2 on each side.
I only did 4 in front, 2 on side and 2 in back the 1st time, being cheap & lazy,
and like I said I had to add 4 more when I started hitting 8's.
I just used plain regular aluminum rivets, I also always tap them down flat with a hammer and a body working tool. Seems to help fit better. Keep at it, you'll do fine.
tektrans
02-14-2007, 06:23 PM
Brad, are those riveted to the fender lip?
Noyzee
02-15-2007, 11:40 AM
yes. rivited to the lip with washers on the other side.
