h/c swap info.
h/c swap info.
the h/c swap is coming up in a little bit. i was curious where u guys bought yours, and if any of u guys would know any good places to look at for a good h/c packages.
Texas Speed
cnc-ed LS6's & choice of camshaft... call them & speak about what your looking for & go from there
rod bolts not necc unless you plan on spinning above 6500 rpm
also OE head gaskets & bolts unless you plan on changing again sometime soon
Internet Mechanic
Depending on your goals and what the intended use of the car. Mine is...
400+ rwhp w/ 6 speed, 12 bolt, 3" steel DS
Not Daily driven, nice days and weekends, occasional track use.
Mods to attain the goal.
SLP cold air kit
Dynatech LT's with out cats
Corsa Cat back
Thunder racing, 230/236 cam @ 112 LSA
Dyno tune
I may do a UD pulley at the same time as the cam since its not doing a job x2
Ive seen it done so thats why I picked these mods.
SLP cold air kit
Corsa Cat back
Dyno tune
Look at the Sponsors Sale Section and Group Purchase Section. You should be able to find some great prices there. Also keep reading in the Internal Engine section. Gather as much info as you can, and learn as much as you can. Plan 2 or 3 times....go over all options and scenarios. Get a firm grasp on what you want the car to do, and what direction you want to go in.........and mod 1 time.
