What will it take to make a 65mm 18 x 10.5 inch wheel fit?
I've found some wheels that I want, but the offset says its a 65mm and the wheel guide states the biggest you can put on the rear is 50mm. What can I do to make these fit?
Well, I would think that the spots would have to be "massaged" 1/8" in spots. I've seen some cars running drag tire setups beat the %$##(% out of their inner fender wells, alot worse than I would think to be necessary to fit some 18x10.5 +65mm would require, but thats just a guess, no hard evidence to back up my assumpions.
Good luck, Shawn
Good luck, Shawn
