Evap block off for truck manifold
Can't seem to find what I am looking for by using the search function so here goes. 2006 LQ4/4L80 are installed in my 72' Chevelle and the evap sonsor hits the hood. Is there a plug/block off plate I can get to plug the hole or do I need to come up with something myself. I saw one post where a spark plug boot and some RTV was used but I would like something a little more permanent.
I used a rubber cap with a lip on it that I found at ACE. I used a piece of .25" X 1" X 1.25" aluminum and a bolt to help seal the cap. I can email you a picture. I had the evap solenoid programmed out. It was hitting my hood also. jeff_dauderman@yahoo.com
Thanks for the info. If it were not for mine hitting the hood I would have probably left it on also. I will just delete the code. If you could send me some pics that would be great. I will send you an e mail.
Thanks again!
Thanks again!
Plug
I made a plug out of aluminum with a o-ring groove and it was held down with a flat rectangular plate the used the original hold down hole. It turned out that for emmissions I needed the solenoid valve so I made a right angle stainless steel adapter tube. I will post pictures later today when I get home
Replacment plug for evap solenoid
Here's a couple pics for options to modify or change out the evap solenoid position if it hits the hood. The plug needs a rectangular bracket with one hole in it to use the old hold down bracket hole.
sawzall wielding director
Mesa that is a really trick relocation tube .
This is how I relocated my EVAP purge valve. Its not nearly as trick, but if you don`t have the ability to fab something up the parts are available at most hardware stores. I use a O ring, 90 degree 3/8" barbed fitting, a short piece of 1/2" PVC pipe, a 90 degree PVC elbow, a 3/8" barbed fitting to pipe thread.
