Clutch went "pop", lost pedal and smoke in the vents...???
Ok, so I'm sitting in a McDonalds drive through and my clutch pedal went "pop" and fell to the floor. It then started smoking through the a/c vents and out from under the hood. Any ideas on what this is or how much $$$ to fix?
Something in the hydralics took a **** on you. Your suspects are.... Slave? Master is easiest to check tho not sure what it could have sprayed fluid on to make the steam. Check reservoir as summit said and you should see a loss of fluid. My money is on the slave cylinder .
Did the car jump forward after the "pop" sound and the pedal dropping to the floor?? If the hydraulics blew out, the pressure plate should have engaged and the car should have lurched forward and stalled out. Unless you had it in neutral of course.
