9in questions....
Old 02-12-2007, 10:51 AM
Z'mnypit's Avatar
Default 9in questions....
I picked up a 9in from a 70's model torino. Now, would it even be worth the hassle to have this thing made to fit in my car? Beside the spring stands, shock mounts, axles, and torque arm mount. What else would need to be changed in order to get this to work in my car? The yoke? I didnt pay anything for it so I dont mind spending some money on it just didnt know if it would work.
Thanks!
Old 02-12-2007, 11:57 AM
CTSmechanic's Avatar
Its not worth it....check out the rear end sticky at the top of the page
Old 02-12-2007, 12:17 PM
keliente's Avatar
Old 02-12-2007, 01:22 PM
Z'mnypit's Avatar
Well there wasnt really info in there about the swap. Other then a post that saide keep the 3rd member and buy a housing from moser. Does this sound right? Even if I did buy the housing from moser with the axle, the 3rd member would work with the new housing and axles right?
Old 02-13-2007, 04:55 AM
EPP
EPP's Avatar
Smile
Correct. I sell the Moser housing and axles for $1,000.00 shipped. You can then bolt the third member from the rear that you have into the new housing. Bob
Old 02-13-2007, 08:18 AM
Z'mnypit's Avatar
Awesome! I will be in with you. Waiting on the tax check. Everything else is bolt right up correct? Im still on the stock driveshaft so is the yoke going to be an issue?
Old 02-13-2007, 11:15 AM
EPP
EPP's Avatar
Smile
Yes, everything bolts right back up. Stock driveshaft will work with a Napa pn# 240-0447 1310/1350 conversion U Joint. Bob
