New TC T-76 is in and tuned.
Old 02-12-2007, 04:08 PM
JD_Z28's Avatar
Default New TC T-76 is in and tuned.
I must say I'm very happy with this turbo and the spool isn't half bad either. I'm running all the mods listed in my sig with the T76 .96A/R. The car makes 620whp and gets full boost at 3800 rpm's. Before the 76 I ran the 60-1 and it got full boost at 3500 and pooped out on the top end. My tuner did extend my rev limiter to help keep in the power band longer. The car runs great for only 12 lbs and on 91 octane The next test will be the track wish me luck
BTW I wanted to give a special thanks out to Force Inductions.com and TRT for all the help and advise they have provided for me.
Old 02-12-2007, 04:18 PM
Josh@KY-Turbo's Avatar
Nice to see some good numbers coming from this unit. Does it have the MPS wheels upgrade?
Old 02-12-2007, 04:22 PM
JMBLOWNWS6's Avatar
That power should be good for a high 9 low 10
Old 02-12-2007, 05:08 PM
JD_Z28's Avatar
You know whats funny is that I don't even know
I'll have to find out....
Old 02-12-2007, 05:12 PM
JD_Z28's Avatar
Not with the stock 10 bolt and the tracks we have out here in SD. All the tracks around here are 1/8th mile. I don't have the tires or rearend to run a low 10 I'll be happy with a mid 10 and hopefully a 135+ MPH.
Before the the new turbo and with 9 lbs I ran a 7.4 @100mph w/1.80 60ft. I think I should be good for a mid 10 1/4th
Old 02-12-2007, 05:30 PM
pdanrichey's Avatar
Good luck with everything.
I'm not sure you'll get traction at all with out sticky tires until maybe 3rd gear...at that rate, you better get a damn good trap speed to run into the 10s. I'm not saying it's not possible, but I think it may be a stretch. Of course if you get sticky tires, then you'll need the rear-end to support them...
I'm shooting for about 460rwhp and maybe 480rwtq with my setup. Without the D/R's and rear-end, I'll be luck to run into the low 12s b/c of no traction and granny shifting.
Old 02-12-2007, 05:42 PM
JMBLOWNWS6's Avatar
Ah I didnt know you had a 10 bolt
Old 02-12-2007, 05:51 PM
JD_Z28's Avatar
I should be able to run mid 10's with my MT ET Street mounted on 16's. I guess theres only one way to find out
Old 02-12-2007, 06:34 PM
Blackbird's Avatar
why such a big a/r ?
I would have thought with that big of a turbo you would want a lower a/r
Old 02-12-2007, 06:39 PM
Dbluegoat's Avatar
whats the torque?
Old 02-12-2007, 06:42 PM
JD_Z28's Avatar
I like having the bigger A/R for the topend and from what I was told you can make more power with the bigger housing. With the 2 step and shifting at 6700 rpms the lag is very minimal.
Since I live at sea level and the air isn't dense I was told that the .96 would work great at our elevation?
Old 02-12-2007, 07:29 PM
Frost's Avatar
NICE.... now get yer *** outta here and make us more videos
Old 02-12-2007, 07:53 PM
JD_Z28's Avatar
Will Do
Old 02-12-2007, 08:00 PM
NYSS Guy's Avatar
Damn man, this is awesome to see. What is your compression ratio? I'm at 8.5:1, and I plan to hit 15 #'s on pump gas. I can't wait to get the fuel system done. Of course, once I do, the next weak link will pop (trans).
Awesome results man, good luck at the track.
Old 02-12-2007, 08:11 PM
JD_Z28's Avatar
I'm right around 8.9. I didn't want to go to low because I wasn't sure how much lag there was going to be with the STS Kit and I wanted decent low end grunt.
Old 02-12-2007, 11:38 PM
99Z28LS1's Avatar
thats amazing JD, sweet numbers and sweet car
+1 to more videos
Old 02-12-2007, 11:42 PM
JD_Z28's Avatar
+1 to more videos
Thanks bro.
How about some vids of your car
Old 02-12-2007, 11:45 PM
99Z28LS1's Avatar
Thanks bro.
i wish my clutch wasnt broken...... there are some on myspace if me racing a H/C/N20 Z28
Old 02-12-2007, 11:46 PM
99Z28LS1's Avatar
http://www.myspace.com/king2000z28
but you have to have a myspace to view it i think 1st video on left. im on the right
Old 02-12-2007, 11:50 PM
JD_Z28's Avatar
I don't have myspace The screen is comming up but the vid won't play
