Head Suggestions
Old 02-12-2007, 05:05 PM
Flipn's Avatar
Default Head Suggestions
Okay, I recently purchased a cam from Thunder Racing 224/224 .563/.563 112 LSA.. with supporting valve train parts (pushrods, retainers, & valve springs).. I would also like to get a nice set of heads to go along with this cam (my goal is to have 400-430whp)... I will have full bolt-ons with H/C.. What do you guys recommend for a good but cheap set of heads..
Old 02-12-2007, 05:39 PM
seawolf18's Avatar
Texas speed stage 2.5, 5.3 heads with 2.02 valves
Old 02-12-2007, 06:57 PM
Moderator
davered00ss's Avatar
I put down 382rwhp with that cam through 4.10's, so any heads should put you in the 400's. AFR's if you can afford them if not I would go with the patriot performance LS6 heads.
Old 02-13-2007, 09:27 AM
Flipn's Avatar
Thanks for the input.. I will be looking for Patriot LS6 heads and Texas Speed Heads..
Old 02-13-2007, 09:33 AM
Studytime's Avatar
I vote for the new trickflow heads, or if more budget minded the Dart 205 heads. These have proven to be some 30hp more powerful than a stock LS6 casting and they sell at a friendly price.
Ben T.
Old 02-13-2007, 11:46 AM
Sigforty's Avatar
Ben T.
I have to agree with this suggestion.
Old 02-13-2007, 02:37 PM
N4cer's Avatar
Dart
Livernois
TSP
Patriot
Old 02-13-2007, 03:18 PM
john563's Avatar
Ive got that cam with TSP 5.3 heads and put down 410rwhp in an A4 with afst 90/90
Old 02-13-2007, 03:22 PM
TXZ28LS1's Avatar
ive seen good numbers from other guys on this site with 5.3 heads and that 224 cam.
Old 02-13-2007, 04:35 PM
88ls1blazer's Avatar
Livernois stage 1 or stage 2 LS6 243 head, cant beat them for the price and quality
Old 02-13-2007, 07:17 PM
Ryan02SS's Avatar
Dart 205's or AFR 205's would make a nice combo with the TR224. For this cam you want a small port with high velocity. .600 300cfm lift numbers mean nothing, the valve spends most of it's time in the .200-.400 lift range. A head that flows strong in this area will be bread and butter with your cam.
The 5.3L heads work nicely as they normally retain a small intake runner and flow decent for a ported stock casting. They also give a nice compression increase without milling and losing PTV clearance.
These budget 5.3L heads will provide a nice performance jump for a small chunk of $$. If you want the most out of the combo and a good platform for further power then go for the Dart, AFR, TFS heads. As the old saying that always rings true is " you get what you pay for".
Old 02-13-2007, 07:24 PM
1stz06's Avatar
Save your money and pick up AFR's or some Trickflow, not that those heads stated above are not decent heads but you get what you pay for!!!
J.R.
Old 02-14-2007, 04:15 PM
Flipn's Avatar
Thanks for the info.. but I couldn't justify spending 2300 bux on a set of heads..
Old 02-14-2007, 04:25 PM
mr2guru's Avatar
Ben T.
For the power they seem to produce, they are worth it. But considering you HAVE to use roller rockers it pushes the price to over twice that of the LS6 heads such as TSP/Patriot/etc... Not exactly friendly. (speaking of trickflows)
If your GOAL is 430whp there is no reason to get the trickflows. That power can be had easily with more budget minded heads.
Old 02-14-2007, 04:41 PM
SilverC5Vert's Avatar
Couldn't have been happier with my Livernois Stage 1 heads!! My cam was had slightly more duration on the exhaust and was on a 114 LSA, but I made 420 RWHP/390 RWTQ with the mods in my sig.
-Rick
Old 02-16-2007, 08:45 AM
Dave@LivernoisDSS's Avatar
We have Stage 1-3 heads in stock and ready to ship. I have no problem grouping our heads in with any dart or afr head. You certainly do get what you pay for, you get a better head for less
Old 02-16-2007, 08:46 AM
We have Stage 1-3 heads in stock and ready to ship. I have no problem grouping our heads in with any dart or afr head. Sometimes spending more doesnt get you something better
