Removing Gorilla Chipz
Old 02-12-2007, 06:28 PM
MannyO's Avatar
Default Removing Gorilla Chipz
Hey maybe you guys can help me out here. My SS had one of these things already in it when i bought it. i was just wondering if anyone knew how to remove these things from my car. Thnx
Old 02-13-2007, 05:22 PM
98noscamaross's Avatar
It's a timing tricker. It plugs into your IAT sensor plug and makes the computer think that the incoming air is colder than it actually is. All you have to do to remove it is unplug it and plug the connector back into your IAT sensor on the air box. If you open it up after you get it off you'll find that it is only a resistor. Hope this helps.
Old 02-13-2007, 11:27 PM
MannyO's Avatar
Default thanks
Yeah i researched it and found out what it was and did but i just was never able to find out the directions to uninstall it. but that sounds pretty easy thanks once again.
Quick Reply: Removing Gorilla Chipz
