Pics of new S60 install.
Looks good. I'm in the process of installing my S60. Judging by your break set up you have a LT1. Even though I have a LS1, I was just wondering if you ran into any problems installing it. Anymore pics.?
I got mine thru Scott at DLS(Driveline Solutions). He is the only company that welds on the sway bar mounts. And i had no real problems with the brakes just had to bend the hard lines the way i wanted them. I got mine for around $2700 w/driveshaft.
more pics.
I need to move the TA in to the other holes, to line up right.
you should beable to see the hard tabs for the brake line like the factory ones. And the size of the axle tubes.
