Top transmission bolts and wiring
Old 02-13-2007, 01:43 AM
Black02SLPSS's Avatar
Default Top transmission bolts and wiring
Just out of curiosity how much of a pain in the *** is it to get at the very top two transmission bolts when removing the trans? Going to be doin a trans swap this summer so im tryin to get an idea of the fun things that await me.
thanks
One other thing when doing an A4 to M6 swap do i need to do any special wiring such as splicing things together and that sort of thing if i get the M6 wiring harness or is that all gonna be taken care of by getting that particular harness?
Old 02-13-2007, 02:20 AM
Phynix's Avatar
the m6 bolts aren't that hard, take your time, I used 2 long 1/2in extentions to my airgun with a swivel socket to grab the nuts
Old 02-13-2007, 02:23 PM
Blk97WS6's Avatar
yup, its not that bad. but you will however, need plenty of extensions to get to them.
Old 02-13-2007, 02:26 PM
87Fake's Avatar
for the M6, the last couple times i had mine out. I just unbolted the tranny from the bellhousing, then the bellhousing from the engine. doesn't all have to go in or come out together. the top bolts are a cinch with the tranny out of the way.
Old 02-13-2007, 02:29 PM
Krab's Avatar
Yes, first unbolt the tranny from the bellhousing, then the bellhousing from the engine. To get the top bolts holding the tranny to the bellhousing, I used a long (~20") extension and it wasn't that bad.
Old 02-13-2007, 04:15 PM
camaroguy26's Avatar
you will still need to splice wires to your clutch pedal for the safety switch and cruise cutoff. I believe that's all you'll have to splice but don't quote me. that is if you have the M6 harness
Old 02-13-2007, 07:51 PM
02silvaZ's Avatar
pretty easy actually, once you drop the tranny mount and pivot the tranny (i supported it with a jack), its wide open compared to most, don't sweat it
