Sponsor Vehicle Projects & Shop Tours - 1998 WS.6 - 402ci, STS, Custom FMIC, Custom Fuel...
TTPMatt
02-13-2007, 01:39 PM
We have been finishing up another couple of turbo projects of late. Here is one of them:
1998 Trans Am Ws.6
STS Turbo Kit (70 trim)
TTP Custom Front Mount Intercooler
- Use of STS system to front of subframe connector, then custom front mount intercooler, brackets, piping.
- 3" piping to intercooler, 3" out of intercooler, steps to 4" to make 90* sweep to the 90mm throttle body
- Relocate Fuse box panels
TTP Custom Fuel System:
- Nasty Performance Fuel Cell
- Aeromotive A1000 Pump
- -10AN feed to y-block split to -8AN for feed to rails
- Aeromotive boost referenced fuel regulator
- Custom Fuel Filter Mount, Y-Block Mount, Regulator Mounts
SLP 402ci Low-Comp Motor (Customer Provided)
AFR 225cc Heads, Large Bore, Low Compression - CNC'd by AFR
TTP Custom Turbo Camshaft - Stage 3
FAST 90mm w/ NW 90mm
Ford 9", 31 spline posi, 3.42 Gears, Steel case
- SLP Sway Bars, front + rear
- Spohn Adj Trans Mounted TQ Arm
- D/S Shop 3.5" Aluminum Driveshaft
TTP Stage 3 A-K Trans Build (Testing the limits of the t56!)
- Exedy Twin Disc Clutch
Here are some teaser pics, please notice that some of the wiring is not complete yet. We will have further pics by tomorrow. Looking for startup tomorrow and completion by the end of the week.
http://www.ttperformance.net/projects/redta_1.jpg
http://www.ttperformance.net/projects/redta_2.jpg
http://www.ttperformance.net/projects/redta_3.jpg
http://www.ttperformance.net/projects/redta_4.jpg
http://www.ttperformance.net/projects/redta_5.jpg
http://www.ttperformance.net/projects/redta_6.jpg
http://www.ttperformance.net/projects/redta_7.jpg
This is our Vice President, Nick Stevko, welding up some intercooler piping to fit to this car.
