Generation III Internal Engine - Would somebody give me a parts list for cam install?
1COOLPC
06-25-2002, 03:00 PM
I would like your opinions for replacing my cam and valvetrain. From my understanding the heads do not have to come off right? I would like to do the cam, lifters, push rods, and rocker arms. Mods I have are below. Would love to get 400rwhp total if that's possible. I want a cam that makes power yet is civil to live with every day because this is my driver. I should probably do a timing chain while I'm in there. Is the oil pump something one does at this time?
So what parts do you recommend?
cam
pushrods
lifters
rocker arms
springs
timing chain
what else? gaskets?
I would like to have everything ready so I don't have to worry about going to the store since my car will be apart. Going to do it over a weekend. Thanks for your help.
SSINFUL
06-25-2002, 03:23 PM
1) Ya ain't gettin' to the lifters w/out removing the heads.
2) Tough to get 400rwhp w/out other mods, like headers, ported heads, etc, etc...
3) Yes, it's a good idea to put in a ported oil pump if ya have an older LS1. What year is yours?
4) Upgraded timing chains are a cheap investment. Several sponsors sell the Rollmaster double roller. Make sure you get shims w/ it (must *slightly* shim the oil pump).
5) You gotta A4 or M6? Is this yer commuter? I'm down here in the S End, so I know from SouthCenter Hill. PITA w/ a super long duration cam and racing clutch.
6) Gasket kits can be had at ThunderRacing (look right at Sponsor list).
7) What have you got for reference materials? Helm? Web instructions?
8) Stock rockers can last a while, depending. Definitely need springs to handle the cam. Depending on what springs you get (similarity to stock) you would need aftermarket retainers.
9) I'm not seeing that list of mods you noted....
98TAauto
06-25-2002, 03:35 PM
we need more info on your car?? year?? a4/m6? Mods?? planned mods??
im ordering the 224 .563 xtreme from ls1speed and on my friends car it made 394 with bolt ons/M6
ill be happy to hit 360 in this A4 but your looking at 30hp pickups untuned and 40 tuned average from what i see
ill also getting chromemoly rods, 918 springs, Katech oil pump, and either a Katech replacement timing chain or a rollmaster..
all the the above are really musts sometime or another so you might as well do them when your putting the cam in <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
definitly get new pushrods and springs for the cam.. oil pump depends on miles really, but alot of guys have to fail at ANYTIME!
1COOLPC
06-25-2002, 03:54 PM
Sorry, thought my sig was in there. Here are my mods and year below.
1COOLPC
06-25-2002, 03:59 PM
OK, so lifters have to stay unless I pull the heads. Pity, the whole thing prompting me to do this is a cold start lifter tick that bugs me.
It sounds like I can do timing chain, oil pump (No oil pan removal here?), cam, pushrods, rocker arms, springs and retainers all without yanking the heads?
Don't worry about the mechanical aspect of it, my Dad's a TV repairman, he has an awesome set of tools. We can fix anything.
So, since I'm doing the cam I should stick with the standard ratio rocker arms? I would just like to put a set of aluminum true rollers on since I'll have it all apart anyway.
So, who makes the best stuff for me? cam, pushrods, rockers, springs, etc?
Dodger
06-25-2002, 05:08 PM
My advise?
Look at the list of sponsors on the right, find the one for Thunder racing, click on it, get the phone number off the top of their webpage, dial it, ask for angie or paul, and tell them you want a TR224 cam kit with Ti retainers, 799.00 +shipping, and your done.
Youv'e got a new LS1, I wouldn't worry about the Oil Pump, but definatly get a better timing chain and sprockets.
98TAauto
06-25-2002, 10:43 PM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Dodger:
<strong>My advise?
Youv'e got a new LS1, I wouldn't worry about the Oil Pump, but definatly get a better timing chain and sprockets.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">not knocking angie and them there, but give ls1speed a look also <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
either one and you cant go wrong <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
TA_2001
06-26-2002, 12:17 AM
here is how I did my cam swap..
http://www.ls1info.com/article.php?sid=49
Parts needed..
( air tube gaskets 2 GM 12553617)
water pump gasket 2 gm 12559271
12557840 Crank Pulley Bolt
12558013 Timing Cover Gasket
12561244 Front Crank Seal ( i did not replace mine )
12560696 Valve Cover Gasket 2 ( i did not replace mine )
depending on your cam but as a minimum
do these springs LS6 springs # 12565117 (16)
bit of coolant and some of your favorite oil,
3 cans of refrig and one of refrig oil your done.
Scalpel
06-26-2002, 11:25 AM
Hey Bart, Levi Procter here for the CF. How ya' doin?
cam:
TR 224 on a 112LSA
pushrods:
Comp Cam or equivalent Chromemoly 7.4" Pushrods
rocker arms:
stock
springs:
Comp 918's with Ti Retainers (not necessary for the Ti retainers but maintains valvetrain stability at high RPMs)
timing chain
JWIS (katech one, cheap insurance)
what else?
Katech Ported/Polished Oil Pump (cheap insurance)
ASP Pulley if you don't have it, LT headers and an LS6 intake (if you don't have a '01 + LS1)
gaskets?
Timing Cover Gasket, front crank seal gasket and a new cam retainer plate.
Save your coolant you drain in a bucket so you can reuse it. 6qts of oil and a new filter and that should be all.
It's easiest to call Paul@Thunder Racing, order their cam kit with Ti retainers for $799 and be done with it, comes with all the gaskets and hardware you need. <img border="0" alt="[Z06 Corvette]" title="" src="graemlins/z06.gif" />
Tools, various sockets, 24" breaker bar, spring compressor, air compressor to keep the valves up, 250 ft-lb torque wrench.
Check out:
http://www.torquecentral.com for the cam install instructions.
Onyx LS1
06-26-2002, 07:39 PM
I have some LS6 springs I'm getting rid of, shoot me an email if your interested.
BTW don't forget MTI. The MTI C2 cam is hard to beat, especially with the more aggresive XER lobes they use. I picked up ~45 rwhp with it, and am just under 400 rwhp with stock heads.
You can't go wrong with any of the above mentioned sponsors. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Dodger
06-27-2002, 12:07 AM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 98TAauto:
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Dodger:
<strong>My advise?
either one and you cant go wrong <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">True, True, Tom at LS1Speed has done me right many times <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
The reason I suggested TR is because of the all-inclusive kit they sell, makes it easier if your not over-loaded with too much info...
BTW HD, you looking to get back at my boy Raven?
Suprising how fast his T/A is...
<small>[ June 26, 2002, 12:09 PM: Message edited by: Dodger ]</small>
