Suspension & Brakes - SFC's
View Full Version : SFC's
knight rider WS6
02-13-2007, 09:06 PM
Is it worth getting the 3 point subframe connectors? I have t tops and thought iy would help out more than the 2 point. Are the 2 points just as good as the 3 point??? Am I adding a waste of extra weight here?? Please help me decide. :lurk:
BlackHawk T/A
02-13-2007, 09:31 PM
IMO, waste. Just get the 2 points.
Silas2k
02-13-2007, 09:34 PM
2 point here and no complaints, from what i read on here there was limited if at all difference between the two...
WS6.Jay
02-13-2007, 09:49 PM
The main purpose of the 3-points is to reinforce the floorpan mounting locations of a tunnel mounted torque arm, that way you don't rip the floor pan apart on a hard launch, it ties that mounting location to the rest of the frame. I'd imagine the 3-points would also help handling by tieing each subframe together in the center(with a tunnel mounted torque arm). For drag racing purposes, other than reinforcing those mounting bolts, I don't think they'll help you much. For autox and such, seems like it would make the body a lot more rigid.
WS6.Jay
02-13-2007, 09:52 PM
Example from UMI's site:
http://www.umiperformance.com/images/2004b.jpg
Sharpe
02-13-2007, 10:01 PM
http://www.umiperformance.com/images/2004b.jpgAn example of what? I don't see anything. Looks like a stock suspended car to me.
:eek:
subtlez28
02-14-2007, 12:12 AM
This is a hottly debated topic here.
Some would say the chassis is plenty stiff, and they are dead weight.
I am one of those people. Had 3pt SLPs--took them off.
Flawless02SS
02-14-2007, 09:53 AM
2 pt are better then nothing, but I say 3 pt all the way. My Kenny Browns are awesome!!
98hardtopSS
02-14-2007, 11:00 AM
i just got everything you see in that umi pic...cant wait to get it all on and see how much it improves traction, i am told lca's and torque arm are a must for drag racing...the 3point is just made if you want to mount the torque arm to the tunnel like you see in that picture. if that doesnt look like a much stronger set up then i dont know what i am missing???
3.4camaro
02-14-2007, 03:36 PM
it will VASTLY improve traction.like night and day
i did a complete switch with all Spohn(and SLP 3-points, and BMR relocation brackets) stuff, and its awesome.
the other day on the street i dumped the clutch at 2500 with sumitomo tires and a ram HD clutch, no spin, no hop, no bog. it just went. :pimp:
BlackHawk T/A
02-14-2007, 09:11 PM
Other way around, actually you prevent the car from twisting on a hard launch. For road racing if you already have a properly setup car you may/may not be able to tell the difference with SFC's.
knight rider WS6
02-14-2007, 10:09 PM
Do you need the middle brace to tie the two sfc's together? I'm talkin' the 3 pont brace.
98hardtopSS
02-14-2007, 10:25 PM
you only need the middle brace if you want to run the shorter torque arm that mounts on the tunnel. it takes the stress off the tranny and is supposed to be alot stronger. which equals better traction and short times. some also come with a driveshaft loop as well
knight rider WS6
02-15-2007, 09:38 PM
Is there anything bad about the 3 point over the 2 point?
knight rider WS6
02-15-2007, 10:29 PM
:eek2: :eek2: :eek2: :eek2: :eek2:
98TA Bandit
02-15-2007, 11:36 PM
Go 2 It is awsome so much tighter, great traction!!!!!!
Pipelayaz
02-16-2007, 09:04 AM
Can you put true duals on a car that has 3 point SFC's?
3.4camaro
02-16-2007, 03:58 PM
yes, you can. your welder just has to not be an idiot.
