Forced Induction - Peeps w/ TURBOS & STOCK eninge!
my01ws6
02-13-2007, 11:24 PM
Just wondering what kind of powers you guys are putting down?
Also how long have you been running the setup on the stock engine?
Please list the kit your running and all your mods and your numbers....if you have a dyno graphs that would be awesome if you could post them as well!! If you have any track times please post them as well! Also if you have had any problems with this kit or from the kit please post them as well.
Im trying to do some research on rear mount vs. front mount setup....Yes I did a search and there was no thread with these questions....I think this thread could be VERY benificially to ANYONE looking to do a turbo set up and doesnt want to spend a fortune to have a little fun while being safe!
Any help will be GREATLY appreciated!! Thanks in advance!!
gametech
02-13-2007, 11:53 PM
I will try to answer questions in order. Stock engine with "over 500rwhp" for over 2 years. Rear mount= less underhood heat and less plumbing problems. Front mount = better efficiency, more power. As for the last question. Everyone who goes FI spends a fortune, and your engine is never safe. This may sound like a cliche, but it is true nonetheless.
my01ws6
02-14-2007, 12:06 AM
Yeah I understand the pros and cons...I just would like to see peoples different setup and what kind of power they are making and with what mods....
I also would like to see how the stock shortblock holds up with boost...
99Z28LS1
02-14-2007, 01:04 AM
you know what mine are, i've talked to you before
my01ws6
02-14-2007, 01:11 AM
PMed!!
ninetres
02-14-2007, 01:47 AM
Link in my sig for my front mount set-up....on a stock bottom end. All was well for 2 months until it got hydro-locked on a rainy day.
RICE ETR
02-14-2007, 04:13 AM
Been turboed for like 20K miles i think. Currently putting down numbers in sig. Stock everything minus valve springs, pushrods, cam and ls6 intake.
my01ws6
02-14-2007, 05:52 AM
WoW how did you hydrolock the car?? Were you driving through a river or what?
Is it a custom kit or what?
my01ws6
02-14-2007, 08:52 AM
cmon guys!! I know there are more of you!!
pdanrichey
02-14-2007, 10:49 AM
I get dyno'd on Tuesday next week...hopefully.
I'm running the STS kit with FMIC, should put down between 7-8psi so I'm hoping for 460-475rwhp and maybe 480rwtq. All stock internals except for valve springs (that was a crappy job!). All my shiznit is in my sig...
I've never been to a 1/4mile track but I ran an 8.90 at 83mph on the 1/8th mile NA. I'm hoping to drop that into the 7's with the turbo but I'm probably kidding myself as I have no sticky tires or rear-end or clutch for that matter to support the power I'll be putting down :( .
99Z28LS1
02-14-2007, 11:59 AM
you also might wanna get the exhaust wrapped, otherwise sitting there waiting to go will KILL the heat going to the turbo..... just my .02
iGoRa
02-14-2007, 12:34 PM
Man , thats a Nice weld job , perfect example how to weld pipes and flanges !
As for the air filter , I would move it to the battery or straight to the right fender. It fits nicely there.
2002/Black/SS
02-14-2007, 12:36 PM
i have a front mount tc76, its all put together im just waiting ona new steering shaft
RICE ETR
02-14-2007, 04:29 PM
yep... twaz a quickie/budget kit. I need to pull it off and have it coated.
MIGHTYMOUSE
02-14-2007, 04:34 PM
jarrod you keep up these posts and your engine will kick the bucket for sure
bowtieman81
02-14-2007, 04:53 PM
Does anybody search any more?
There is a "my stock shortblock lives" thread with hundreds of replies in it. There is also a stock bottem end thread about 7 down from this one
my01ws6
02-14-2007, 07:21 PM
Yes actually I did do a search...show me a thread that shows stock blocks with turbo kits...Im trying to figure out whether the majority of people run a rear mount or front mount and have more success on a stock block with one or the other...
Also what the point of even posting if you have nothing positive to add to the thread...
Murdock
02-14-2007, 08:44 PM
Of course not. Makes to much sense. :bang:
**searched "stock" titles only, forced induction**
http://www.ls1tech.com/forums/search.php?searchid=4726683
Particularly these two threads:
http://www.ls1tech.com/forums/showthread.php?t=618016&highlight=stock
http://www.ls1tech.com/forums/showthread.php?t=292721
Tada!!! What do I win? :judge:
bowtieman81
02-14-2007, 09:09 PM
Thanks Murdock. Sometimes I think the FI section is starting to be like the IE section where guys come in and ask the same questions over and over.
The front mount versus rear mount has also been discused quite a bit already.
Here are a couple other posts with good info in them:
http://www.ls1tech.com/forums/showthread.php?t=428072
http://www.ls1tech.com/forums/showthread.php?t=208864
Smearin
02-15-2007, 05:41 PM
Boosted 3k miles... check sig..
RooRnZ28
02-15-2007, 10:46 PM
500 miles and so far so good... check sig for more info
