Can I splice a new connector onto an O2 sensor?
Old 02-14-2007, 10:55 AM
BADFNZ's Avatar
Default Can I splice a new connector onto an O2 sensor?
Last time I went to the track, one of my O2 connections came undone without me knowing. All of a sudden the car wouldn't idle but my car has always had idle problems so I didn't think anything of it. The next day, I looked under the car and the O2 sensor was unplugged and had been dragging on the road for about 300 miles. Needless to say the connector was fubared.
I switched out the sensor with one of my old ones and it runs decent now but still not as good as it should. I'm guessing the reason I took this O2 sensor out in the 1st place was because it wasn't working too great.
So I'm wondering, can I take the connector off this sensor and splice it in the other sensor? Is there any issues in doing this?
Old 02-14-2007, 11:49 AM
jub jub's Avatar
You can but not recommended, unless you know someone with the skills to do it right. Otherwise, just bite the bullet and buy a new sensor.
Old 02-14-2007, 12:01 PM
yobabiesdaddy2001's Avatar
Yea, the same thing happen to me. I bought o2 extensions and was almost like a different car.
Old 02-15-2007, 01:56 PM
BADFNZ's Avatar
Well I'm going to do it anyways. I can't stand the way it's running.
Old 02-15-2007, 02:50 PM
It will work if you get the connection correct. I would recommend sodering the wire.
Old 02-15-2007, 03:23 PM
oange ss's Avatar
good luck soldering those wires, i dont know what the deal is with them but they dont solder for ****
Old 02-15-2007, 06:50 PM
Billf6531's Avatar
I believe that the wires are steel, not copper, thus the preferred crimp connection. The O2s also get their oxygen reference through the wires (space between the strands, actually) so the convential wisdom is not to attempt a splice. That said, I left a 1/2 inch gap between the insulation and the crimp the last time I did one, and it seemed to work fine, at least it was still working when I sold the car with 30K kilometers on the crimp.
Old 02-15-2007, 07:00 PM
oange ss's Avatar
cool, thanx for the info
Old 02-15-2007, 07:02 PM
brad8266's Avatar
I spliced mine a while back to extend them and they are just fine, no codes either. Be sure to make the splice connection tight and solid.
Old 02-15-2007, 09:52 PM
slow's Avatar
I cut mine to fit, but used proper GM metripack connector crimp terminals, and crimper. They've been fine for a couple of years now.
Ryan
