Cat piss spots
Cat **** spots
Hello all! I was curious to know if anyone has had a dog or cat **** on your wheels and spot them really bad and if there are any remedies other than having them recoated.I have tried just about everything to get it out and nothing works that wont eat the clear coat. Any ideas or other threads that have talked about this will be greatly appreciated. Thanks
Originally Posted by tbs98z
Shoot the cat!J/K The ammonia in cat **** is like acid If you dont catch it right away it will etch to the clearcoat. Reclear and see above!
I used to hate that untill I found out how quiet .22 shorts are! Get those *******!
Don't know bout getting it off. If you are agaisnt killing the little **** heads get some long leather gloves and next time you find that **** on there find the nearest cat and scrub it off with the ****** cat's face and back. Learned that from my potna he claims it works the cat will be pissed. I'm getting fired up just thinkin about it I hate that **** so much!!!
Originally Posted by craz1469
kill the cat, skin it, use fur for cleaning the wheels.....**** peta
or in my case.....dog, I will at least have more fur to clean the wheels with
Haha. Catpiss SUCKS so bad. Its SO erosive! That **** glows under a black light man, your best bet, kill the cat, as for dogs that chronicly **** on your tire, do as my neighbor did, plug an extension cord into the wall, run it out to your car, cut it put one wire on the rim, make sure its on the inside and tape it on there nicly (so when **** goes down it wont arc and do too much damage to your rims), then leave a hose on with water right by the rim where the dog would step and have the other wire in the water. When the dog takes a **** on that rim, that will be the last time he ever does it, feel free to test this your self while your barefoot.
A ******* cat just pissed not on my wheels but right below my door! I dont have a gun but I do have a gas airsoft pistol that shoots 430 fps (im only 18), I saw it coming back, hid behind a snow bank, POP POP POP! nailed it havent seen that ****** since.
Cat **** is fucken horriable, nothing like dog ****! My sister had a cat, my fucken god!
Fucken nasty, even when the dog **** on the floor it was never as bad n ****...I hate cats
