a4 to m6 who made the switch?
Restricted User
I will be doing the swap myself within the next couple weeks. I usually hit the track a few times a year. Should be more fun dumping the clutch at 6000 rpm and running through the gears...
no regrets at all. I am extremely pleased with the swap and how I can rip through gears now. I haven't been to the track since I first got the car though so I can't tell you how that's going. I am planning to once I get back from my deployment and get the car running again (my fuel pump went out). I even gained an average of 5 more mpg after the swap
I bought the entire kit from a guy on here that was swapping to a TH400 setup. He sent me EVERYTHING I needed minus clutch safety switch, pilot bearing, and PCM for 1400 bucks. He had a pro 5.0 shifter, upgraded 3-4 steel fork, and custom clutch with about 10,000 miles on it. I did the install myself with my dad helping me lift the transmission up to put it in. It was really simple, I had it all torn down and modified the tunnel for the shifter and wiring in 6 or 7 hours and finished installing it the next day in 4 hours. Of course taking my time, talking to friends stopping by, etc. etc. Didn't have a lift but it would have helped if I did. I just raised the car enough to slide the transmission under it. I just used that sticky in the manual section for all the information I needed. I know there's a lot of posts but everything you need to know is in there. I bought the GM manuals but didn't need them at all.
One of the best mods that I have done to the car bar none. I was getting bored with my stalled a4 after about 2 years of driving it. After the swap, the car is totally different now with the M6 in it and my excitement is now back to when I first purchased the car.
I have swithched back and forth between autos and sticks in my 55 Chevy. There is no substitute for the fun of banging gears. But... The bogging sinsation of launching an undergeared (for the strip) 4 speed car consistently makes you think back on those easy days of leaving with a stall. You six speed guys have it made. Slick shifting close ratio tranny that can drive with 4.56 or 4.88 gears on the highway with ease kills on the starting line and provides tons of excitement. I may be looking into the t56 sometime in the future. It's just that when it's all said and done, it's far cheeper to replace internal components on a muncie than a t56. When subject to a regular diet of 6000+ rpm shifts without lifting the gas or flashing more than 300 rpms (nice clutchwork huh?) periodic replacements of synchros and mainshaft gears (2,3,& input) become necisary. I did not like the price of replacing just synchro & collar assemblies in my Tremec 5 speed last time and have not raced with it since. I also found the car performs so much smoother runs with less bouncing with a closer ratio tranny. In that regard, the T56, like the Muncie, definitely rules the strip.
Originally Posted by texada
Did you have your harness changed out? Also will I need to reprogram my computer to correct the speed odometer?
Yes I swapped harnesses when I did the swap. If you can, I would recommend doing the same. Splicing can be a headache if you don't know what you're doing. I guess I was lucky enough to have a friend looking for an auto swap. We had both of are cars in the shop at the same time. Took everything off his and moved it to mine, vice versa with my stuff.
Yes you will need to reprogram. But it's just not for the speed odometer. There are a lot of different tables when you compare an A4 to a M6. Your car will not run right unless you get a full tune after the swap. Since my buddy had a similar setup to mine, we just swapped PCM's. When I got it back to my tuner he tweaked it a bit and now the car runs great.
the only drawbacks in my opinion are the fact that if you beat on the car and launch hard... you'll need a good rear end/driveshaft, and down the road - a built trans. (syncros go quick w/ sticky tires). so that's just money.
also - it'll take a little more suspension/tire to hook well on a manual trans.
but if you're not at the track or beating up on it all the time, there should be NO drawbacks. better gas mileage, and WAY more fun.
