hurst comp plus / hurst billet plus
Originally Posted by vatechguy3
how does it shift other than reverse?
thanks
tony
thanks
tony
I said I think it takes a lot of muscle to get it in reverse, not too much, and on a comparative basis (compared to the SS Hurst oem shifter), it does. My oem shifter was easy/simple to throw into reverse. IMO, with the Billet/Plus, it takes substantially more effort to find reverse. It's managable, but different. I think my wife would have difficulty with it.
To answer the question of how it shifts otherwise, IMO, it shifts fine, but, I don't see much difference in the throw of the Billet/Plus and my oem shifter. Additionally, the Billet/Plus shifter stick is actually taller than the oem stick. I'm not sure I like the orientation of the stick either, although it looks like the Pro-5.0 and LSS are similarly oriented. The Billet/Plus stick is oriented further to the left and to the rear than the oem stick. The tower on the Billet/Plus is located nearer the passenger side than the oem shifter, and it's a tight fit relative to the console. I've seen others advise that you should find someone who has the shifter you're thinking about getting and try it for yourself first. I think that's sage advice. Find someone in your local f-body club who has what you're thinking about buying and try theirs first.
And, FYI, Hurst is now B&M.
Comp is the older model I believe before they came out with the billet plus. The comp uses a cast base I believe vs machined billet of the billet plus. I had looked at both but found a steal on an open box billet plus so I picked that up. I believe the comp plus also comes with the chrome stick where it is optional on the billet plus. I put a WS6 store short stick on my billet plus anyways and love it with my Hurst pistol grip shift handle.
