General LSX Automobile Discussion Non-technical LSX related topics.
cam and head set up-HELP
Old 02-15-2007, 09:27 AM
lwsprtn11's Avatar
Default cam and head set up-HELP
i have the patriot 5.3 stg 2 heads with a 59cc chamber
i plan on running a 100 shot
i have a TSP 233/239 .600/.603 112+2
niether heads or cam are installed yet... but would that cam be decent or whats everyones opinion i'm not the type to throw in a prodution cam i always got custom grinds in the past
Old 02-15-2007, 09:38 AM
Ericbigmac83's Avatar
Cool, thats the setup im gonna get when i have the money. Post up some numbers when everythings done.
Are you gonna have to flycut with it milled to 59?
Old 02-15-2007, 11:08 AM
lwsprtn11's Avatar
no i shouldn't have to
Old 02-15-2007, 11:54 AM
staringback05's Avatar
just a ?....are you going to have any lowerend work done?....those heads are going to raise your compression a good bit and with a 100 shot there will be a good bit of strain on the other parts of your motor....
with higher compression there are other things you need.....
Old 02-15-2007, 04:14 PM
lwsprtn11's Avatar
nope it will be fine on a 100 shot... my buddy has the same set up on his TA and runs a 150 shot all day it just bumps it up to a 11.3 or so
Old 02-15-2007, 04:27 PM
bww3588's Avatar
keep telling yourself that.......... your going to need some bottom end work with that setup. mabye not right off hand but eventully after enough shots of the sauce, your bottom end is going to take a ****.
