Vibration
Vibration
I have a vibration in my car, it gets real bad in third around 2000 Rpm Besides that it does it a little bit in fourth, any ideas what it could be?? Out of balance drive shaft, maybe wheels, or could i have a siezed u-joint, it also makes a bit of a clunk shifting into gear....So im thinkin it might be time for new u-joints...anyhelp is appreciated.
i have almost the same problem ive changed almost everything.i had my a4 built,had fuddle 3600 changed it to a yank ss3600,changed drive shaft with new joints, built rearened,put zr1 17/11 on back had 17/9's,changed torque arm,put qa1 adj rear shocks,still vibs in third gear at about 3000. its worse when letting off the gas.i'm going to check axles and motor mounts.pm me if you find anything!
Many of these trannies clunk when they shift. I've had vibes from over-tightened u joints, out of bal tire, bad drive shaft, and now with a solid trans mount I get it in 3rd gear....too many possibilites. Sorry.
Its kinda constant to the rpm, and it does get worse when letting off the gas, dunno guess its time for the old trouble shoot one thing at a time till it stops, start with the cheapest and go from there, thaks for all the advice, when i figure it out i will post the problem
