Size WG and BOV
Size WG and BOV
How do you know what size BOV and Waste gate to run? Different size for amount of hp you want to run? Looking to push 1000rwhp or really close to it
I have twin tial 44m gates and they worked fine for all boost levels I've tried, and a single 50mm bov but I've heard of people running two before when they are running a lot of boost
Originally Posted by 93 4mula
I am running a single turbo setup. So would a 50mm work for what I nieed?
You an get a JGS 50mm wastegate for ~$379 ... about the same price as a 44mm Tial.
http://www.jgstools.com/turbo/index2.html
Waste gate size is going to be dependant on turbo and motor size AND how much boost you want to run. If you want to run a lot of boost you won't need a very large waist gate, but for low boost a larger WG will be required to be able to bypass enough exhaust gas to regulate boost.
Originally Posted by RealQuick
GT47-88 right? I would go no less than a Tial 44mm WG and start with one 50mm BOV.
Originally Posted by ls1king000
kyle, do you run a front sway bar?
No i do not..... and i do drive around on Skinnies with power steering..... it has it moments and i do **** people off when im getting on and off the freeway when there is a sharp turn........ im that guy doing 30mph LOL
Kyle
