GTO Front sump oilpan swap issues
I have a fbody ls1 and dipstick was in block behind starter! i swaped to gto pan pickup tube and all that and moved dipstick to front dipstick hole in pan. What do i use to plug the rear dipstick hole ? I have been searching around and no luck. My friend when he bought his gto pan it came with a little rubber plug he said! mine didnt. please help.. i want to start it tomarrow to see how she runs. maybee a local harware store or autopart store will have somthing that will work. thanks!
sawzall wielding director
There is a factory GM plug for that hole. Your best bet would be to go to GM and try to get one, they were used from the factory on GTO`s so they should be available. You may be able to find something at the hardware store or autoparts store, but I would try GM first.
If the hole is tapered/stepped you might try stopping by a lawnmower repair shop, the carburetors on them use small aluminum plugs like that. If it is a large enough shop they may have some in stock in bulk.
Or just grab a tapered rubber vacuum plug and stick it in till you get the correct plug.
yeh i was thinking that i have some various sized vacuum plugs rubber! i will try putting a oversized one to stuff in there. thanks. how would i go about finding the part number ?
