Sick TA after Header and PCM Install
Old 02-17-2007, 08:39 AM
Torque_Wrench's Avatar
Default Sick TA after Header and PCM Install
Hey guys....ever heard of this? I need some help.
Installed a set of Pacesetter LT's on a 98 TA, and installed the Nelson Performance Tuned PCM. Driving the car to the exhaust shop to have the rest of the exhaust welded up, and I noticed the car will surge and buck....and it will backfire bad! It also feels like it's only running on 4 cyl.'s
I swear I think the damn thing has fouled out the plugs on my engine Bank 2.
Got any ideas?
Old 02-17-2007, 08:53 AM
99huggercamaro's Avatar
did u do a tune up with the headers?
Old 02-17-2007, 08:59 AM
does it miss at an idle? the wires are very know for breaking inside and causing missfires. i broke a few of mine. i replaced them with msd's
Old 02-17-2007, 09:02 AM
dpw41285's Avatar
did you do plugs w/headers. if not you prolly cracked the porcelin. if you cant figure out take it to the shop and have the tech II hooked up. most likely plugs and wires. have you let the computer adjust yet?
Old 02-17-2007, 10:04 AM
Well....I am the shop so....the Tech II shows nothing conclusive. I have now found that all 4 plugs on Engine Bank 2 are fouled. So I'm replacing them now.
Old 02-17-2007, 10:15 AM
Magnet's Avatar
are you sure you hooked the 02's up correctly?
Old 02-17-2007, 11:18 AM
Well....I got Nelson Performance to turn off the rear O2 sensors because we're running a cat-less Y pipe.....but the front 2 are hooked up....but I'm afraid the wires may be broken....possibly.
Old 02-17-2007, 09:48 PM
DrkPhx's Avatar
Make sure they disable the Cat Over Temp (COT) tables. If not, this will dump excess fuel.
Old 02-17-2007, 10:08 PM
SSwanner's Avatar
i know its obvious but did you plug the coil packs back up?
Old 02-17-2007, 11:21 PM
sidewayz28's Avatar
i had a lot of those symptoms once when a wire wasnt connected to a spark plug
Old 03-01-2007, 08:46 AM
OKay guys I found out the problem. After driving the car with open headers only, it seems that I fouled the plugs. So...I replaced them with the AC Delco 41-985 Iridium plugs and now the car runs perfect. I want to thank all you guys who chimed in to help me out and offer me their advice. Thanx friends.
