No Spacer behib Slave Cylinder?????
I have a spec stage 3 with the spacer. The pedal grabs at the end. If i take out the spacer what will happen? will the pedal grab close to the floor??? All info apprecited. Thanx...
If you take the spacer out it will grab sooner, in my car some machanic put the wrong one in. Its was too thick so the clutch would not be all the way out. In return i burned up a clutch in 300 miles.
