1994 4l60e compatibility Question
Old 02-18-2007, 07:36 AM
shaneatlh's Avatar
Default 1994 4l60e compatibility Question
Hi, I have a Performance 4l60e transmission on my 1994 trans am GT and want to know if this can bolt on to a 95-97 TA or Z28. Any info would be great. Thanks
-Shane
Old 02-18-2007, 08:24 AM
jay_lt4's Avatar
it will bolt in fine,, but the 94 uses on/off for the tcc apply,, the 95 and newer use pwm(pulse width modulated) signal for the tcc apply
you would need to use a 94-95 pcm flashed/re-programmed with a 94 bin file and i think there is 1 wire that may need to be changed at the trans harness
Old 02-18-2007, 09:08 AM
FLT
FLT's Avatar
The 93-94 do not use the pwm for the lockup. The 95 unit and it's electronics are a year all of their own. 96 and later are all interchangeable as far as the electronics are concerned for 96 and later vehicles. You will need the ECM of the vehicle to match the year of the transmission. Good luck Vince.
Quick Reply: 1994 4l60e compatibility Question
