For you guys with a Ford 9" Rear
What's up- I am looking at one of these from Moser to go into my 95 Z, I have seen a few people with this, and it is pretty reasonably priced. What all did you guys get to make it work? I plan on getting the Housing and Axles, and getting a Ford 9" Auburn Pro Series Posi Differential, and then 3.73's. Summit sells Gears for Ford, but it says for 8.8", are these the same? Also, what Pinion Yoke do I need if I go with this setup. If I need to know anything else, throw it in.
Thanks.
Thanks.
8.8 is a completely different diff than the 9". 8.8 has a rear cover like the 7.5 GM, I'm sure you know the 9" has a drop out pumpkin. Just do a search for - gears ford 9 - on summitracing.com and you'll get a bajillion results.
