02 zo6 window stays up.
My sisters 02 zo6 drivers side window stays up. She said all the other buttons work fine just not the one for the drivers side door. I told her that it just might be the unit that is in the door pannel. Am i wright? I told her that she can just pop it out of the door panel and disconnect it and reconnect a new one and pop it back in. I have done this before on my camaro a few times. Just making sure that it is just the button on the door and not the hole motor. Any info would help.
Thanks.
Thanks.
Closed ex-Sponsor Account
Sounds as if your master window switch is possibly bad.
Pop out the switch, and check for a voltage sence coming out of the switch in the down position.
You could always hot wire the motor to go down (or up), just to make sure it works!
