Stereo & Electronics - Considering replacing monsoon..
View Full Version : Considering replacing monsoon..
MasterEvilAce
02-18-2007, 04:43 PM
I currently have a 2001 Camaro SS, with the stock monsoon system. The door speakers are both blown, and i'm considering replacing the speakers, and adding a sub. I'm looking at possible options.
I am thinking about getting a 10" stealth enclosure from subthump, but i'd like to know what sub to get with it
I also need to know what kind of speakers to get, as well as an amp.
Also, is it possible to use the stock monsoon HU as a radio/cd player (and also because it already works with the steering wheel controls).. but pass the signal off to the amp and run the speakers off of that, for a nice stock look, with improved sound? Or is the stock HU really bad quality wise?
I am very into sound quality, and not so much pure power. As long as I can hear the music clearly with the t-tops off, I'm good.
I'm also wondering about rear fill.. I think I would like some speakers in the rear, even though it's recommended against.. if I wanted them, what should I get, and should I put them in the hatch or in the sails?
I'm also wondering how much this would run me. I'm looking for affordable quality. Thanks.
fredmr39
02-18-2007, 04:48 PM
Yes you may keep the stock HU if you wish....but as you thought, it is the worst component as far as quality in the stock system, as it puts out a lot of distortion.
As far as sub/amp selections, etc.....how much are you willing to spend?
MasterEvilAce
02-18-2007, 05:02 PM
I don't really have a budget, and I don't know the usual prices for car audio. Looking for someone to put together a system that should fit my needs. I can save however much I need, but I am really looking to see what I can get, and what it'll cost. I know the rest of my monsoon probably won't last much longer, so I'm looking for alternatives to just replacing bad speakers.
If the HU is really that bad, recommend a replacement. I'm into a clean-look, preferrably with a volume knob rather than buttons, blue lighting, and easy to make work with the steering wheel controls
I listen to electronic music.. such as Drum'n'bass, trance, breakbeat.. I occasionally listen to rock, metal, very rarely rap, etc.
you2slo
02-19-2007, 02:15 PM
Alpine has some nice HU's. That is the way I'll go in the next month or so.
