SLP TCS Control were does it go??
Old 02-18-2007, 09:07 PM
WS6 Canada's Avatar
Default SLP TCS Control were does it go??
On a 2001 M6 trans were exactly do you plug the SLP TCS in. Is it right on the rocker switch itself or is it hidden behind the radio.??? SLP isnstrutions are not good???
Old 02-20-2007, 01:14 AM
Tom01ss's Avatar
pull the radio cover off and you'll see where.If memory serves me right, it plugs right in the switch back.
Old 02-20-2007, 09:54 AM
pontiac's Avatar
Take the little plate with the switch strait out and unplug the switch, and plug cars wiring in to your SLP thing, and plug your SLP thing in to your button, and push SLP thing back into the hole where you plastic plate came from and then replace the button and plate and it will work, keep in mind it only works the first time you try and state car, if you have to hit the key again, it will not work.
Old 02-20-2007, 04:16 PM
WS6 Canada's Avatar
what do you mean the first time you start the car???? is it not reversed always???
Old 02-21-2007, 11:34 AM
pontiac's Avatar
not if let say you kill it at a red light (asumming you have a M6) then when you hit the key again, it will not. it only does it the first time the box gets power like when the key is truned from all off to starting and on, once it has been triggered to do it it has to see a loss of power and then power again to make it do it again.
andother example would be if you hit the key and for some reason the car did not start on the first try (never really happends on mine but who knows you get the point) once you turn key to off and start the car then it will do it again, i say thats 98% of the time it works fine just will not work if something odd happends
Quick Reply: SLP TCS Control were does it go??
