New LS1 Owners - Newbie Tech - How Long Will An LS1 Aluminum Engine Last?
corvet786c
02-19-2007, 07:32 AM
Aluminum corodes and steel rusts,Just wondering with proper maintance How many years and mileage on an LS1 engine will last until you have to buy another one Thanks.
300bhp/ton
02-19-2007, 08:32 AM
Well the block itself will most likely out last you.
Remember while aluminium may be new to Chevy V8's it's been used for the best part of 100 years for automotive engines.
LS1Formulation
02-19-2007, 09:13 AM
The LS1 was touched by the hand of god, it's eternal!
99Z28LS1
02-20-2007, 12:41 AM
take care of it and it will take care of you my friend. +2 for the post above
thosewhohatedmecreat
02-20-2007, 12:49 AM
ive seen some with 250k on them running strong as hell.
staringback05
02-20-2007, 12:53 AM
how long and hard do you want to upkeep your motor,...thats how long it will last...
BLKWS.6
02-20-2007, 12:55 AM
Well, go to the dynometer section and look for my thread "Post your high mileage numbers"
I found a 51K miles M6 01 Z28 BONE STOCK that made 304whp and a 118K mile 99 WS6 M6 bone stock that made 296whp with a DIRTY! air filter and 306whp with the filter removed.
118K miles and still dynoing what it did the day it rolled off the assy. line pretty much.
Take care of it and these motors last a LONG time. Just dont run it low on oil!!! They like to spin bearings when you do this...
Blk97WS6
02-20-2007, 10:27 AM
+1 :jest:
Honda Hunter
02-20-2007, 11:02 AM
That's pretty much all there is to it.
RPM WS6
02-20-2007, 12:22 PM
Yep. If the original question was (and I beleive it was) geared towards how long the actual block will last, I can tell you right now that, unless someone melts it down, your engine block will still be intact long after your skin, eyes, organs, blood, and hair are long gone.
So worry more about the condition of your body than the longevity of your aluminum engine block.
WS6NIGHTMARE
02-20-2007, 05:36 PM
I just turned 192K last week. Im still runnin down cars with under 100K.
Sluggish
02-20-2007, 06:39 PM
my buddies ws6 has been driven hard....with 2 jl 12s in the back that hit pretty good.......his shit runs strong and does rattle, or make any odd or annoying noises
Mike00ss
02-20-2007, 07:44 PM
This picture says it all….
http://img96.imageshack.us/img96/6117/ls1giftfe1.th.png (http://img96.imageshack.us/my.php?image=ls1giftfe1.png)
crazboy99
02-20-2007, 07:49 PM
ls1's are like twinkies.....they last FOREVER!!!
02NHRAtransAm
02-20-2007, 07:53 PM
x2 :rock:
RPM WS6
02-20-2007, 08:02 PM
LS1..... the 8th Wonder of the World. :D
staringback05
02-20-2007, 08:08 PM
anybody ever take a tour at the plant and see a block get molded?
02NHRAtransAm
02-20-2007, 08:12 PM
that it is..... they are :pimp:
RPM WS6
02-20-2007, 08:19 PM
This process is done by God behind closed doors...errrr....gates I mean. Nobody is allowed to watch. :D
02silvaZ
02-20-2007, 09:04 PM
:werd:
somws6bird
03-03-2007, 04:08 PM
Mines at 90K and still runs, drives perfect.
cowboysfan
03-03-2007, 07:52 PM
I'm sure you are talking about corrosion here. so only concern is if you live near sea water and drive it alot then wash engine compartment with fresh water and drive around enough to dry it. if you drive close to beach like say several hundred feet from waterfront, might need more care then say if you lived 200 miles away or more from ocean water. hope this helps. just take care of it in a orrosion preventive way.
fuerzaws6 :drive:
Rede
03-04-2007, 10:02 PM
:hail: :hail: :hail:
