Generation III Internal Engine - Are 862 5.3 Heads good?
camaro98z28
02-19-2007, 10:57 AM
With my mods listed below, I dynoed 426 RWHP with these TEA 1.5 Heads. The heads were ported and milled a bit. I was wondering if I'm doing ok with these heads? I was also thinking about going to the AFR 205 heads and was wondering what gain I should see.
slt200mph
02-19-2007, 11:19 AM
Good numbers for a automatic car..those 5.3 TEA heads are pretty good..I would not make the change you might not pick up anything.. :)
prostock_bigblock
02-19-2007, 01:14 PM
agree.
camaro98z28
02-19-2007, 01:21 PM
So going to better head might not make more power? :(
slt200mph
02-19-2007, 02:08 PM
It might not be a better head..just because you pay more does not mean it is better. My TEAs flow 316 cfm that is as good as the AFRs. If you were a six speed car you would be in the mid 400s which is pretty good. The only way you are going to pick up any HP is going with a ported 90/90 combo ... the latest and greatest on the aftermarket head scene now days are the $3000 trick flow heads..I would go with the 90/90 first..after you get to the mid 400s adding more HP is pricey compared to the first 100+ HP you gained with your mods .. :)
PS the L92 heads and intake might be good if you had bigger cubic inches but with a 346 size motor the trick flows are the shinizznit now.. those heads and the 90/90 are bad ass ... Vengeance Racing just did a 346 with the trick flows and it made 524 rwhp.. it was a six speed car and thoes are stout numbers .. :judge:
camaro98z28
02-21-2007, 06:43 PM
Yeah I was thinking of getting the FAST 90/90 set up. 20 HP more would be great plus look great. I wonder what else I can do to make a few more HP numbers.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
