Spec flywheel w/ another brand clutch???
I have a spec 3 with the billet steel flywheel in my 2000 SS. The clutch is worn out and slipping, and not 100% sure if I want to stick with spec for the replacement.
Will the spec flywheel work with another brand, for example a Ram HD???
If I can put a new insert on the spec flywheel for around $80 and use that I would be very happy.
^^^ more commonly called re-surfacing. it's the same principle as having your disc brakes cut/turned. they take off a few thousanths on a lathe to ensure a "true" (completely flat) surface.
