weird miss after long tube install
installed long tubes, cat back exhaust, new plugs and wires and now it misses. You can hear it a little bit at idle but it is horrible at anything over part throttle. You can ease into and it will pull fine up to 6 grand but the second you stomp the gas it bucks, pops and backfires. Checked all my associated connections, ran an ohm test on the plug wires and they are all good.(within .010 of each other) O2 sensors are good and I let the car warm up to operating temp before driving it. the car has probably 30 miles since the install. And the fuel filter has maybe 100 miles on it.
