Ugh! Need help with MAP PID in EFILive Scan
Hi,
I downloaded the new version and everything is fine. But now somehow my MAP PID is now showing in volts (PID GM.MAP) in my saved PID files and logs. I know this is not the correct MAP PID I originally had it set to because it always read kPa. Any help would be appreciated.
Originally Posted by 5.7 ute
You need to log the SAE.MAP pid not GM.MAP for kpa.
Originally Posted by Black02SS
Which map are you referring to?
