9" guys inside
9" guys inside
what torque are you running I just found out(the hard way) that my UMI TA will not fit my new 9" I just bought!!! so what TA is the best for this thing? I have longtubes and true dauls.Im thinking of the spohn 405 becouse Ill prob. end up with a th400 anyway so nows a good time to get it off the tranny
funny you replyed I was gonna call you tomm. ots a moser 9" and the TA is the non-adjustable. I was told it would work with a 12bolt and 9" when I bought it. is their anything I can do to make it work? like grind off some of the weld or noch the bolt holes?
I got an update.....
will I grinded the T-total hell out of it and it now fits but I would not use words like "minamal" or "a little" grinding Im gonna say MAJOR GRINDING I had to cut the top plate compleatley off for it to barley fit..just for the record this is the only bad experience I have had with UMI stuff everything elce I have is very nice but IMO they need to change their design on the non-adjustable TA or clearly put on their website that it will not work on a 9" without major work
IMHO, if the UMI fit the factory rearend fine, then the fitment problem is the fault of the new 9" rearend, not the UMI piece. My Random Technology piece was pretty tight on the factory 10-bolt, but it fit... in the end (with persuasion). I guess what my point is... I only expect a company to make a piece that replaces factory pieces, if two aftermarket pieces conflict, and one of those pieces is known to have replaced factory pieces fine, I would then blame the "engineering" of the other aftermarket part...
hehehehe, if you sell it to me now I might actually be able to afford it Glad you got it to fit dude.
well I got the rear in tonight but now I seem to have 2 new problems
1. the driveshaft looks th be 11/2 too short now
2. both tires looks like they are turned in REAL BAD
any ideas?
any ideas?
fuerzaws6
