New Stall Possibly slipping
well it seems like sometimes something is slipping like i'll give it gas the rpms go up but theres not as much power behind it as when i first got the stall converter put in...any suggestions why this would be...and usually the power loss where i deffinitly noticed is around 35-45 roll...like i said it only happens sometimes...its kinda cool out but not really cold i mean its florida..lol..is there any specific fluid i need to put in besides the dexron 3 atf that would stop or control the slipping if thats what it is?...
thanks for the help
thanks for the help
so how can i tell if the tranny is slipping...and if it is ..is there anything i can do...that will prolong the life of it...or is it pretty much done with and i better start saving up to by a new tranny? also if the tranny is slipping should it throw off the ses light:?
thanks for the help
thanks for the help
i believe i am slipping...Lets say i'm at a stop just pulled out of my driveway...so i'm in 1st gear...i give it some gas the rpms go up i barley start to move then a sudden grab takes place and i go...so this is my tramssion slittping right?
any ideas on what i can do check or w/e i would appreciate any help...since i dont really have any money and this is my daily driver so any advive will be appreciated thanks...
My tranny has went out twice in the past. The 1st one was the stocker and when I added H/C, a week later it went down hill. For me, it was fine and as soon as it would shift into 3rd, RPM's shoot up and would no accelerate.. My "Rock-On" transmission that I spent 2G's on, did the exact same thing about 800 miles and 4 track passes on it.. So, both times it was the 3rd/4th packs. Now, its shipped off to FLT to get it done right.. How many miles you have on the tranny?
how can i tell if my tranmission is truely slipping or something else...would there be a light? could it be fluid..ect..and whats the pcs?
thanks...also is it possible for converters to slip..i mean could the problem be the converter?
LS1Tech Sponsor
Well yes a converter can slip if the sprag is bad, Also the lockup clutch can slip also , But it would be hard to tell you how to determine wether its a trans slip or converter slip well except for the lockup that would set a code if the converter clutch slipped 1870. Try to find someone local there with a stall and get them to drive your car and give there opinion , Stalls particularly if there loose can feel like the trans is slipping anyway and still be normal
__________________
well when i firlst got it put in it was fine a month ago...now somwetimes when i'm at a light and try and go the rpms go up barley moving then it'll catch and go...so should i just have someone check it out...also if the trans is slipping the ses light will or will not come on? thanks...if its the trans going i might need to get a loan and buy performabuil lvl 2 trans..lol
thanks
thanks
