slp smooth below strong enough?
Old 02-21-2007, 09:47 AM
rufretic's Avatar
Default slp smooth below strong enough?
Has anyone used one with boost? I'll be running about 9psi and I plan on using the slp smooth below from the nick williams tb to a 3 1/2" pipe. It fits so I see no reason to buy another coupling unless it won't hold the boost. Anyone ever tried it?
Old 02-21-2007, 10:42 AM
SELLSZ06's Avatar
should be able to do a little more than 9lbs
Old 02-21-2007, 11:48 AM
99Z28LS1's Avatar
i have the STS 90 degree that comes with the kit and i would think that the smooth bellow would hold, just make sure you have it on there kinda tight
Old 02-21-2007, 12:08 PM
WAHUSKER's Avatar
I've had mine to 15lbs. I even have my meth nozzle installed in it now & it still holds.
Old 02-21-2007, 12:29 PM
99Z28LS1's Avatar
that should be the green light to go ahead and do it my friend
Old 02-21-2007, 12:44 PM
rufretic's Avatar
Cool, thanks guys.
Quick Reply: slp smooth below strong enough?
