Clutch/Flywheel recomendations
Old 02-21-2007, 10:34 PM
BatmobileWS6's Avatar
Default Clutch/Flywheel recomendations
I would like some recomendations for a clutch for sure. And possibly flywheel...
I have a 2000 trans am ws6 M6. Mods are just bolt ones with 373 gears. I plan on cam and possibly heads in spring and more down the line. I would like something capable of ~450whp but is good for street drivablity and liability with occasional track usauge.
What is your thought on ls7 and stage 3s. Im open to all opinions though.
Thanks
Old 02-21-2007, 10:35 PM
JKDZ28's Avatar
Ram Powergrip HD .... thank me later
Old 02-23-2007, 05:36 AM
BirdmanLS1's Avatar
0Z700 Textraila w/aluminum flywheel then thank ME later.
Old 02-23-2007, 10:08 AM
tech memeber
kars10_4's Avatar
SDPC has a great deal on the LS7 clutch and flywheel combo right now, 439.95 shipped. I just ordered it myself. Rated at 550hp with great street manners.....can't argue with that.
Old 02-23-2007, 11:12 AM
Bryan @ Speed Inc.'s Avatar
i just ordered the ls7/ls2 clutch setup too. for your h.p. numbers, i'd say it'd be perfect for you.
it'll hold the power and have great street manners
Old 02-23-2007, 11:18 AM
Phynix's Avatar
get the tex, more money now will save you more money later
Old 02-23-2007, 04:32 PM
LS1TECH & Trucks Sponsor
Scoggin Dickey's Avatar
For a budget build up, I'd agree you'd be happy with the LS7 clutch kit we have on special!
For a slightly more aggressive clutch setup, that will handle a bit more abuse down the road if/when you upgrade and get some more power, the Textralia OZ700 would be a good choice! We keep both in stock, feel free to PM or call me if I can help and we can talk about your needs and select the best clutch for you!
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old 02-23-2007, 07:07 PM
JKDZ28's Avatar
Thats the clutch I wanted. But, most people don't have that kind of money for a clutch. I would have went with a steel flywheel though.
Therefore my vote still stays with the Ram PGHD
Old 02-24-2007, 01:41 AM
sidewayz28's Avatar
would the LS7 clutch hold with 420+rwhp N/A + a 120 shot you think?? or is that asking for trouble?
Old 02-24-2007, 10:42 AM
deejaydaze's Avatar
Didn't see the price on the site. Textralia is not listed as a manufacturer on your site either....
Old 02-24-2007, 10:51 AM
deejaydaze's Avatar
I've been hearing that you get what you pay for.
After 4 Spec3's and knowing I'll have my car for a long time. I'm willing to take the chances.
RAM HD 400.00 + RAM Steel flywheel 250.00? = $750.00
Text OZ700 clutch + Text Steel flywheel = $970.00
I just don't understand how someone can afford a new clutch setup and think that there is a lot more money going into a Textralia setup.
Old 02-24-2007, 11:27 AM
JBsZ06's Avatar
I'd vote for the one that doesn't get the stock clutch pedal to stick to the floor during hard acceleration.
I've been hearing guys say who had that pedal sticking situation that the stock hydralyics and the textrella was their cure..
I have had two ls6 clutch assemblys and one ls7 clutch assembly..along with ls6 hydralyics replaced and I still have the occasional pedal sticking issue.
its a real pain in the butt so next time I'm going to try textrella setup..
I'm going to cover the lines with 3/8ths fuel line and heat wrap...
I'm going to install a clutch pedal stop as well.
Hopefully that will do the trick...
Good luck in whatever you decide but I believe the clutch assembly is a place to spend money because once you get on the pedal sticking train its hard to get off..
Have assembly balanced properly before install as well.
I never did the work myself but this issues a pia.(if you have it_down the road you'll know what I'm talking about...)
LS7 clutch is heavy. Weights not your friend in rotational mass.
Old 02-24-2007, 06:42 PM
JKDZ28's Avatar
RAM HD $379 shipped + Crosshatched factory flywheel $FREE = $379
Works perfect.
Old 02-24-2007, 06:55 PM
Dex
Dex's Avatar
Always help to stop the problem and not blame the clutch. Everyone seems to blam the clutch, but the clutch is holding just fine it the hydralics that are causeing the problem and not releasing. I think everyone that has this problem has headers also or the problem started after installing headers.
Sorry read to many post of people bitching and blaming the clutch every time then replaceing it multiple times and still have the same problem.
Old 02-24-2007, 07:47 PM
93camaro_zzz's Avatar
I would say a textrilia. I have the LS7, and it is a gret street clutch for that amount of power, but as soon as you want to put some tires on it and go to the track. You are going to hate yourself.
Old 02-25-2007, 11:37 AM
deejaydaze's Avatar
Works perfect.
What are you saying....did you machine the stock flywheel and slap in the RAM HD?
Old 02-25-2007, 12:09 PM
Phillymu's Avatar
That is exactly what he is saying. You dont need a Billet flywheel, how high are you going to spin your engine?? 7k? The stock flywheel will be just fine
Old 02-25-2007, 04:22 PM
deejaydaze's Avatar
From what I understood you might get away with resurfacing the stock flywheel only once. Am I wrong?
Old 02-25-2007, 07:50 PM
JKDZ28's Avatar
Negative... kinda but not really. Let me elaborate.
The method of crosshatching the flywheel is basically taking sandpaper and cleaning up the surface of the flywheel by hand (with a grinder). This eliminates "hotspots & rough surface areas".
By doing this, you allow for a real nice clutch engagement. Just like stock in my case with the RAM Powergrip HD.
This is because when you crosshatch the flywheel you take off NO MATERIAL. Therefore, you don't have to go through the big headacke of finding the correct shim in order to compensate for a resurfaced flywheel.
I learned this technique from a member here that swore by it. I tryed it and was absolutley pleased 100%. There is a major shop here in town that also does this method. He informed me that almost all flywheels can be done this way unless they are too bad off and have to be resurfaced. He also told me that he hasn't had to resurface a flywheel in over 3 years.
Hope this helps, I highly recommend it.
Old 02-25-2007, 08:41 PM
Sluggish's Avatar
what grit paper.....I'm going to order a ram next week
Quick Reply: Clutch/Flywheel recomendations
