air fuel ratio guage
Old 02-22-2007, 08:20 PM
pro2low's Avatar
Default air fuel ratio guage
search isnt working for me! i am trying to hook up an air fuel ratio guage i need to know which wire to connect it to from the ignition. and also the o2 sensor! im lost i dont like electrical work! thanks -dave-
Old 02-22-2007, 10:27 PM
pro2low's Avatar
ok all i need to know what do do is where do i wire the A/F gauge to the o2 sensor? i know i need the sending wire. which one is it? and where shoud i splice into it at?
Old 02-22-2007, 10:31 PM
HeavyWeight's Avatar
Which wire did you connect to the ignition.
Old 02-22-2007, 10:35 PM
pro2low's Avatar
the red wire from the gauge i hooked into a fuse with one of those adaptors. i just need to know where to hook it up to the o2
Old 02-22-2007, 10:37 PM
LS1Tech Sponsor
Rob@EFIAlchemy's Avatar
its purple i believe pin 8
Old 02-22-2007, 10:43 PM
pro2low's Avatar
hook it up from the computer?
Old 02-22-2007, 11:29 PM
That's what she said...
TheBlurLS1's Avatar
Why don't you spend a little more and get a wideband. The narrowbands don't work for **** once they go outside of stoich.
I have a Dynotune LC-1 with the square guage. VERY inconspicuous, easy to install, and works badass.
Old 02-22-2007, 11:31 PM
pro2low's Avatar
i already bought t and it is halfway installed if i would have known i would have
Old 02-22-2007, 11:34 PM
TheBlurLS1's Avatar
Well proceed!
I might be installing one for a friend coming up, not sure if he's getting a wideband or just a guage, so don't be suprised when I PM you.
Old 02-23-2007, 12:32 AM
pro2low's Avatar
not a problem ill figure it out tomorow after work im done for the night haha
i still need to know where to connect to the o2 at. though to anybody else that knows!
Old 02-23-2007, 09:25 AM
Todd157k's Avatar
Purple wire on the flat connector of the O2. Use crimp butt splice connectors and tape them up good afterwards so they don't get wet.
Old 02-23-2007, 12:54 PM
pro2low's Avatar
i heard i should splice into the extension does it matter which side i splice into?
Old 02-23-2007, 12:59 PM
SSpdDmon's Avatar
The propper signal wire should be wire B on the O2 connector if you want to splice into it from the sensor. Just look at the connector as they should be labeled in the plastic molding. See diagram below...
Old 02-23-2007, 01:03 PM
pro2low's Avatar
ok that helps. does it matter which side i use i was gonna just use the drivers side since it closer.
SSpdDmon's Avatar
Driver's side is fine...
Old 02-23-2007, 01:04 PM
SSpdDmon's Avatar
Check it with a voltmeter if you can (while it's running) without getting burnt. It should be swinging between .3 and .7 mV.
Old 02-23-2007, 02:34 PM
pro2low's Avatar
i put my meter on it and none of the wires fluctuated.....could the fact that i have open headers right now be screwing with it?
Old 02-23-2007, 02:39 PM
horist's Avatar
it should still be fluctuating... but yes having open headers will mess up the fueling
Old 02-23-2007, 02:45 PM
pro2low's Avatar
thats weird.....what are the up stream and down stream o2's different. if so whats the delco part number?
Old 02-23-2007, 02:49 PM
horist's Avatar
they're the same, I think it's part 13111
