137.1K miles-Compression reading results
Old 02-23-2007, 12:58 PM
SHINER's Avatar
Default 137.1K miles-Compression reading results
How bout these for some compression readings:
Current mileage- 137.1K
1- 158psi
2- 168psi
3- 156psi
4- 169psi
5- 160psi
6- 165psi
7- 160psi
8- 164psi
I was suprised....not too shabby, what do ya'll think?
Mods:243 heads, 232/234 Cam, comp 918's
Old 02-23-2007, 01:30 PM
seawolf18's Avatar
Still has plenty of life left in it.
Old 02-23-2007, 01:44 PM
V6 Bird's Avatar
In the compression dept maybe. Bearings...only time will tell with them.
Old 02-23-2007, 03:34 PM
SHINER's Avatar
Ive used nothing but synthetic oil, changed every 2K. They should be ok...i hope..
When I did my cam install the cam bearings were not that loose at all..
Old 02-23-2007, 04:03 PM
7w/aswap's Avatar
The compression ratios are pretty good for that high of mileage.
Old 02-23-2007, 04:07 PM
SHINER's Avatar
thanks man, feels good to hear that(you have no idea)
landstuhltaylor's Avatar
i dont what to compare them to. is their an "good" to number to compare them too?
Old 02-23-2007, 04:12 PM
SHINER's Avatar
i think stock they run around 170-175 psi, i could be wrong tho.
Old 02-23-2007, 05:05 PM
2 SSlow's Avatar
i did one around 80k miles....165-180psi for me... i would like to do a leakdown test to really find out though...
Old 02-23-2007, 05:08 PM
SHINER's Avatar
im also using a full synthetic 0-30 oil too. Im sure if i was using a thicker dino oil it would have made better compression...i would think the thicker oil would help the rings make a better seal.
Old 02-23-2007, 05:39 PM
Ryan02SS's Avatar
Where those dry or wet readings? Pretty good for that mileage.
Old 02-23-2007, 05:40 PM
SHINER's Avatar
dry or wet? I unplugged the fuel injectors, so....i guess dry
Old 02-23-2007, 05:49 PM
SUTTERERMAN85's Avatar
your compression readings will be different than a stock #'s because of your cam and your mileage. you are with in 3-4% so you are good to go there as stated. bearings could possibly be a problem but if you have good oil pressure and keep oil changed on a regualar basis then id say go with it. FWIW i have a 148K almost and drive it like its stolen. she is starting to puff some oil on decel so i am assuming its rings cause i have new heads( less than 7k) on them so its not valve guide seals. good enough of a reason to do a 370
Old 02-23-2007, 06:26 PM
BLKWS.6's Avatar
Oil on decel is usually valve-seals. With that mileage though it could easily be rings or the PCV system sucking under vac.
Old 02-23-2007, 06:51 PM
no PCV anymore thought that was the problem also. could be valve guides seals but doubt it the heads were brand new when iput them on. i would say its the oil ring letting it get by. the new motor should fix this problem
Old 02-23-2007, 06:59 PM
SHINER's Avatar
dude there is a guy selling an 02 motor outta a WS6 with 43K for 1800 bucks
you should jump on that deal now b4 someone else does.
Old 02-23-2007, 10:32 PM
i have an 6.0l block and l92 heads in my garage need a few more pieces still
Old 02-24-2007, 11:56 AM
Boosted 99 TA's Avatar
my car was makin some nice compression as well, i have 140k on it..and when i took my heads off the cylnder walls still had a nice 60* cross hatch and not to much of a piston ridge.
Old 02-24-2007, 11:59 AM
CougarL92's Avatar
still plenty of life left
Old 02-24-2007, 01:19 PM
SHINER's Avatar
So i take it if im not burning any oil, and getting good compression, I have the green light to buy some nice flowing heads instead of a new shortblock.
Not burning oil=bearings are in decent shape
good compression=good effciency(sp?)
I change my oil every 2K miles, and up keep my fluids and buy nothing but the best fluids, etc.
I guess im ready for some nice heads, and tires...what do yall think?
