Problem on keeping engine running
Old 02-23-2007, 06:49 PM
noname024's Avatar
Default Problem on keeping engine running
I have a 96 camry and I can't seem to keep the engine running after turning it over. It'll start...then immediately die. I can keep it running by slightly holding down the gas pedal while starting it. But if I let up off of the accelerator it just drops the rpms real low and wants to die, then will die once I completely let off. I can't figure this one out. I think maybe its a bad tank of gas and there's some water in the gas, but I wanted to get some input on this before I do anything stupid.
Any thoughts/ideas are welcome. Thanks.
Old 02-23-2007, 07:04 PM
staringback05's Avatar
check your fuel pressure and the regulator to
Old 02-23-2007, 08:22 PM
noname024's Avatar
Alright, thanks. I'll check it out.
Old 02-24-2007, 02:30 AM
96slow6's Avatar
What work have you done on it lately? When did it start? Not just what day, what were the exact conditions, as best you can.
Old 02-25-2007, 09:52 PM
noname024's Avatar
Never mind it. I got it running. I just put some gas treatment in it to see if there was some water in it. Low and behold, after keeping it running for a little while...I let off and it idled down as usual. I figured I just got a tank of bad gas. Thanks anyways all.
