So who's ready for the LSX?
Old 02-23-2007, 08:10 PM
KurtRardin's Avatar
Default So who's ready for the LSX?
I believe that I heard that the LSX is suppost to be released in March, this year, and it should go for anywhere from $1800 to $2500. Anyone have any plans?
I like how this block is suppost to be extremely strong, and since the cylinder walls are so thick it can be rebuilt many times, or bored out to a monster.
I am thinking that as soon as i get out of college I will go with an LSX block and a pair of assembled L92 heads from SDPC.
Who sells LS2 rotating assemblies?
My plan, which i am certainly ready to hear debated, is to buy a pretty much OEM LS2 rotating assembly and use the L92 heads and LSX block. This motor should last forever, especially without boost or nitrous.
Are there any drawbacks to the L92 head/LSX 6.0 combo?
My headers will still fit on L92 heads, correct?
And since the valve springs on the L92 heads from SDPC are rated to .650 lift then I should have no problem with majority of the cams available.
Old 02-23-2007, 08:11 PM
LS1TECH Sponsor
Katech_Jason's Avatar
Katech is ready for the LSX. Should be an interesting summer
Old 02-23-2007, 10:39 PM
CougarL92's Avatar
im still dreaming
Old 02-23-2007, 11:20 PM
qqwqeqwrqwqtq's Avatar
Hell yeah I'm ready. Plans are 427ci, ETP LS7 heads and twin turbos.
Old 02-24-2007, 12:20 AM
Quickin's Avatar
Dare I say....I'm on a list waiting patiently
Old 02-24-2007, 01:35 AM
red90cobra's Avatar
wish i could afford another build this year
Old 02-24-2007, 08:53 AM
383ss's Avatar
pretty much any sponsor on the right is going to sell aftermarket LS2 rotating assemblies. they are all the same for the LSX family. why you would want to use stock LS2 parts, I have no idea. the crank is fine, but why use the rods and pistons?
Old 02-24-2007, 09:46 AM
Mssingkid's Avatar
Wish the block wasn't so heavy, but i'll probably still end up buying one. Bring on the BIG cubes!
Old 02-24-2007, 02:17 PM
Red99C5's Avatar
I agree. Why have a extra strong block if you aren't going to put the extra strong compenents inside. Might as well just use a LS2 block.
Old 02-24-2007, 02:41 PM
aggiez28's Avatar
why?
sems like a great way to waste $$
Old 02-25-2007, 04:08 PM
VENGEANCE's Avatar
Since the block is supposedly good to 511 cubes, have any companies come out and said they have pistons/rods/etc for a 511 cube motor?
Are there pistons out already that would work for a 511 cube LSx? prices?
I did a search but came up short....
Old 02-25-2007, 04:24 PM
11 Bravo's Avatar
I'd be more worried about having to have custom headers made for the tall deck than pistons.
Old 02-25-2007, 04:33 PM
VENGEANCE's Avatar
Why? where would the headers hit? is there that much of a physical difference between 9.22 and 9.7 to the point where a good set of kooks wouldnt work?
Old 02-25-2007, 04:39 PM
Sawzall and Welder Mod
Whistler's Avatar
Probably. The engine decks are 90' to each other, so as the decks increase in height they also increase in width.
Old 02-25-2007, 04:53 PM
VENGEANCE's Avatar
good point, i didnt really think about that. i guess its going to be one of those things well find out after the block is released.
back to my pistons question, anyone?
Old 02-25-2007, 06:23 PM
KurtRardin's Avatar
The reason i was considering stock ls2 internals was because all the stroker kits that i found were almost $4000. If there's a budget rotating assembly out there then please let me know. I dont even know what a oem ls2 kit would cost or where i could get one.
I really just want to take advantage of the cheap L92 heads, and the l76 intake, and a strong block that would last for a long long time.
Old 02-25-2007, 06:48 PM
11 Bravo's Avatar
A stock LS2 piston is too small for this block.
Old 02-25-2007, 06:52 PM
KurtRardin's Avatar
The write up in GM High tech said that you could take the LS2 out of your vette, take all the interanals out, and put them over into this block. Doesnt it start out as a 3.999 bore?
Old 02-25-2007, 07:03 PM
11 Bravo's Avatar
Hmmm, maybe it does. Still a waste imo. An Eagle setup is cheap. Aftermarket cranks, pistions and rods are no less reliable than GM stuff.
Old 02-25-2007, 07:10 PM
Wnts2Go10O's Avatar
well... you could use a stock ls series crank and just get a decent piston/rod/ring setup. OR just get a used LS2 because the block hasnt been broken.
what I would do is a stock LS crank, 6.125 Eagles, and a 4.125 or more bore. LSX block isnt really for a budget street build
Quick Reply: So who's ready for the LSX?
