LS2 Timing chain in LS6
Old 02-23-2007, 10:11 PM
FourG63 97GST's Avatar
Default LS2 Timing chain in LS6
ok, this cam swap is adding up fast, so far i'm $1300 in parts
but yea, this is the final piece of the puzzle. What would I need to get an LS2 chain in my Z? Is it a direct replacement?, I was worried about maybe the sprockets are different also and may need to be doing some modifying. I work at GM, so I preferred to use GM parts since I get it at cost instead of buying some kit. is it possible?
Old 02-24-2007, 06:49 AM
rk98ls1's Avatar
thats what i ran in my ls1 just went from stock chain to ls2 chain used same sprockets
Old 02-24-2007, 07:36 AM
99blancoSS's Avatar
yes, will work
Old 02-25-2007, 02:34 AM
Halloran's Avatar
Same question here, so I can get the LS2 timing chain with upper and lower sprocket and will replace the stock LS1 timing chain and sprockets? Will I need a new under drive pulley while I'm down there?
thanks
Old 02-25-2007, 07:04 PM
bad6as's Avatar
do you realy need to replace the oil and cam gear or is that not needed
