Sponsor Sales & Specials - New Holley 750 Double Pump for sale $350.00!!!
EPP
02-24-2007, 09:53 AM
http://www.holley.com/data/divisions/pictures/largeHolley.jpg
The famous Holley double-pumper.
Holley's Model 4150 four-barrel carburetors are available in a variety of configurations for street, strip, and track performance. Holley uses their time proven design to make sure you have all of the flow you need, to keep your engine running its best. Plus, with power-valve blowout protection for trouble free operation and a 100 percent wet-flow test, these carbs set a standard for performance and reliability that's hard to beat.
Holley 750 cfm double pumper carburetor features dual metering blocks to allow fine tuning of the secondary jetting and dual accelerator pumps for additional fuel under initial acceleration. Four corner idle system for precise idle control. Manual choke. Dual feed fuel inlets for constant high volume fuel delivery.
http://www.holley.com/data/types/pictures/medium%20DP%20intro.jpg
Double Pumpers
http://www.holley.com/data/products/pictures/large0-4779C.jpg
The 0-4779C is finished in the classic look
Number of Barrels: 4
Carburetor Flange: Square bore
Choke: Manual
Fuel: Gasoline
Secondary Type: Mechanical
New or Remanufactured: New
Fuel Inlet: Dual
CFM: 750
Carburetor Finish: Dichromate
Ford Kickdown: No
Throttle Linkage Type: Universal
Features
* Dichromate Finish
* Manual Choke
* Power Valve Blowout Protection
* Dual Metering Blocks
* Dual Feed Fuel Inlets
* Model 4150 w/ Center Hung Floats
* 100% Wet-flow Tested and Calibrated
* Mechanical Secondaries(Dual Accelerator Pumps)
* 4-Corner Idle
