LT1 waterpump idea...
Old 02-25-2007, 11:47 AM
94blownz281's Avatar
Default LT1 waterpump idea...
has anyone welded the water pump outlets that they don't have use for anymore? i have rubber caps on the ends but i want a sure way to keep anything from coming out of these outlets. i removed,oil cooler,all my hvac stuff so these are the outlets i'm talking bout.
Old 02-25-2007, 09:31 PM
Anyone?
Old 02-25-2007, 10:59 PM
That's what she said...
TheBlurLS1's Avatar
I'd just run a hose out of one, and into the other. I believe it's designed to have some flow through those ports, not sure how good it is to block them off.
You talking about the heater hose outlets or radiator bungs?
Old 02-25-2007, 11:31 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Run a hose directly to the opti... I hate that it is right there. That was retarded design on GM's part. Water + Electricity = $500 on LT1
Old 02-25-2007, 11:54 PM
those ports are only for stock oil cooler,HVAC. so blocking them off will not hurt anything. alot of guys on camaroz28.com just use hose tie offs or caps. i would rather go another route.
