Maximum cubes out of LS6 block?
Old 02-25-2007, 04:29 PM
VENGEANCE's Avatar
Default Maximum cubes out of LS6 block?
Whats the biggest cube you can get out of an LS6 block, SAFELY. Like not to the point where the cylinder walls about touch each other either.
was debating with a few people, wanted to see what some of you engine gurus had to say.
Old 02-25-2007, 04:47 PM
Beast96Z's Avatar
You can only hone the sleeve itself .010". Your only going to gain cubes by going with a stroker crank. You can do a 382 or a 396 depending on the crank you use. If you resleeve the block, that's a diffrent story, however, LS6 blocks are not used in the resleeving process due to some poorer charecteristics in the design.
